SLP underdrive pulley
Old Sep 16, 2006 | 01:46 AM
cav101's Avatar
Default SLP underdrive pulley
have a buddy selling one, but i dont know if it is worth the $$ or not. not lookin for big gains, just wanna get a few small things done. already have longtubes and ls6 intake. Search is down, so i thought i would post this up. thanx for the help.
Old Sep 16, 2006 | 07:53 AM
shouldaboughttheZ's Avatar
it should give you 8-10hp. Make sure you get a new crank bolt, and it will take a smaller belt.
Old Sep 16, 2006 | 03:29 PM
TheBlurLS1's Avatar
That's what she said...
LS1howto.com's camswap section has a writeup for the pulley change. You will need a longer bolt or a threaded rod/bolt/washer to get the pulley started back on so you don't strip the crank.
Old Sep 16, 2006 | 03:44 PM
Ls1CamaroGuy87's Avatar
are they easy to install?
Old Sep 16, 2006 | 04:09 PM
TheBlurLS1's Avatar
Sometimes. Mine came off without a hitch using a puller rented front vatozone, but some people have problems. Some people have to call in the national guard and cast a spell on their crank bolts before they come out.
Putting the pulley in the oven at about 250-300* helps with install as well.
Old Sep 16, 2006 | 06:35 PM
ShevrolayZ28's Avatar
IMO if you're going through the trouble of installing the pulley, you may as well stick a cam in it as well....and an oil pump...and a new timimg set.
Old Sep 16, 2006 | 06:41 PM
cav101's Avatar
thanx for the tips...i may just do that. this is just for my driver....but im sticking a turbo'd LSX into my 67 firebird, so this is all just practice
Old Sep 16, 2006 | 07:08 PM
bjamick's Avatar
shevrolay has a good point that would be a smart idea ge the cam and install it while your down there.
