ORY banging the floorboard
Old Oct 4, 2006 | 10:57 AM
Waveridr85's Avatar
Default ORY banging the floorboard
What is an effective and proper way to get rid of this. Its hanging down really low too.
I have the Pacestter headers with the Texas Speed ORY.
Help would greatly be appreciated.
Old Oct 4, 2006 | 11:09 AM
SOMe WS6's Avatar
mine was banging when i first put it on and several months later it just stopped.
Old Oct 4, 2006 | 11:24 AM
jmm98LS1's Avatar
Put poly motor mounts in....not the most fun job in the world but it's cheap ($50) and worth it. It'll cure your exhaust banging too.
Old Oct 4, 2006 | 12:25 PM
dedge's Avatar
Believe it or not Mufflex makes a bump-stop hanger for the y-pipe. I know it sounds like a crock but check it out on Thunderracings site.
Old Oct 4, 2006 | 12:29 PM
02ls1ta's Avatar
be a chearp ***.. get some heater hose and some band clamps works everytime tehn send the other 48 bucks on
Old Oct 4, 2006 | 01:07 PM
beaSSt's Avatar
Buy the Mufflex.
Get under your car and see where it is hitting (mine was my Spohn adj. TA). Use a pry bar on your y-pipe to put an inch or so clearance at the point where the y-pipe hits your car.
The slide a rubber exhaust hanger in to maintain the clearance while you install your Mufflex clamp. When the clamp is secure remove the exhaust hanger rubber.
Worked like a charm on my car and a lot easier than installing poly motor mounts once your headers are on.
Old Oct 4, 2006 | 03:07 PM
Andros's Avatar
get poly motor mounts 1st, if needed add a hanger afterwards
Old Oct 4, 2006 | 03:14 PM
98RedZone's Avatar
Mine stopped after poly trans mount and torque arm bushing.
Old Oct 4, 2006 | 04:35 PM
z28_n_tx's Avatar
x2, ive had the heater hose on there for over 2 months now and no probs.
Old Oct 4, 2006 | 04:38 PM
1sick'98WS6's Avatar
this happened to me when my clutch was on its way out, buy yeah motor mounts too
Old Oct 10, 2006 | 12:14 AM
Waveridr85's Avatar
Well, I tried the heater hose but it seems to vibrate even more! It didnt bang as much btu a Ifelt halla vibraion under even mild acceleration. I guess I should have doen it right and just goen with the poly mounts.
Old Oct 10, 2006 | 12:57 AM
89tang's Avatar
Yup poly mounts, i had a slight banging/vibration after installing the LT's and ORY the mounts fixed it. BUT they were a PITA to install not much room, it took me a couple hours.
Old Oct 10, 2006 | 08:36 AM
SUTTERERMAN85's Avatar
poly motor mounts and tranny mount it what you need.
Old Oct 11, 2006 | 02:25 PM
02ls1ta's Avatar
do it like 4 times around the area that is bangin but if it vibrates really bad did you notch your k member? cuz that might have something to do with it.... my guess is that that header is riding right up next to it
Old Oct 11, 2006 | 04:01 PM
farnoush's Avatar
Poly motor mounts. I just ordered them myself.
Tried the heater hose on my car and a friends and it felt like it made the vibraton worse.
Old Oct 11, 2006 | 05:36 PM
nodnarb481's Avatar
i wish i knew about that bump stop thing earlier..
Old Oct 11, 2006 | 06:30 PM
bandit1's Avatar
I had the same prob and I acually had a frind that worked for Doctor Gas they make nascar exhaust and they have a neat frame clearence pipe and I put it in and now they are gunna make a custom y for anyone that is guarenteed not to hit and flows better than a reg 3 inch it useds 4 in but pressure crushed and it looks good too and sounds great.
Snuffles's Avatar
I had problems with my QTP Y banging and hanging low.
What I did was this:
Jacked the exhaust up to about where I wanted it to sit.
Measured the distance from the Y-pipe to the floor.
Then I went to Maaco and for $11 I had a J-hook welded to a U-clamp.
(That included the hook, clamp and welding.)
The J-hook was bolted to the bottom of the floorboard and the U-clamp was put around the Y.
I will post pics up if you want to illustrate exactly what I'm talking about because I'm sure this is confusing as hell.
This solved the banging and the hanging low issues.
Poly mounts will probably solve the banging but won't fix hanging low.
Old Oct 11, 2006 | 06:33 PM
bandit1's Avatar
One other thing I know alot of people are saying poly mounts and U bolt it to the floor bouard but unless you like to feel every vibration in your car those 2 solutions do just that I know I spent a week, and had it changed 10 times to come up with a solution that worked and I dont have to ever replace a mount, hanger, heater hose, or have to feel the vibrations cause I tried that and it sucked
Old Oct 11, 2006 | 06:45 PM
Coy's Avatar
Coy
Motor mounts, adjust the ory as neccesary. If it still bumps, then use the mufflex hanger, but the mounts should cure it.
