gutting my cats
Gains will probably be minimal, but the increased flow can't hurt; although you may trigger an SES light if you haven't disabled your rear O2 sensors. You will need to disable the rear O2's with PCM programming or get O2 simulators if you want to avoid SES lights.
Good luck!
i unbolted the y pipe cut the cats off put them on the bench removed all the insides and then i welded in a pipe so it wouldnt resonate and welded it all back together.
it should
blacksskid07 but i have another question i asked the muffler shop how much it would be to replace my cats and they wanted 375 bucks a cat they were feeding me some bullshit about how i cant use the cheap magnaflow cats beacuse they are not made for obd-2 cars they wanted to 800 bucks to do both cats i said
and went to some other muffler shops and they gave me the same price + or - a few bucks but i want to make sure the magnflow cats will pass smog before i buy them. The Best V8 Stories One Small Block at Time
