Painting Headers?
Old Oct 9, 2006 | 11:22 PM
SS4Luck's Avatar
Default Painting Headers?
So im buying the uncoated pavesetters and i dont want them black i wanna paint them white, it i just got hi temp paint would it work? or is there some other special pant i have to get?
Old Oct 9, 2006 | 11:47 PM
Starz T/A 17's Avatar
The Hi temp paint would be the stuff to use, but MOST LIKLY IT WILL FLAKE OFF, it is well worth it to get ceramic coated, not only to prevent rust but to keep the engine bay cooler, the coating helps insulate the heat and keep temperatures down. But back to the painting, I dont think ive ever read anyone having long term (meaning more then 4-5 months) success with painting headers
Old Oct 10, 2006 | 07:20 AM
gillbot's Avatar
I used high temp paint on mine and they still look good as new after about 5 years.
Old Oct 10, 2006 | 07:54 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1. Go to Wal-Mart
2. Ask/find BBQ grill paint
3. Self Check-out
4. Spray headers
5. Done deal
Old Oct 10, 2006 | 08:20 AM
gillbot's Avatar
Originally Posted by orangeapeel
1. Go to Wal-Mart
3. Self Check-out
4. Spray headers
5. Done deal
+1, mine look WAY better than most "coated" headers i've seen.
Old Oct 10, 2006 | 01:03 PM
SS4Luck's Avatar
^ what color did you paint yours? im thinking white... i know i dont want just plain black though
Old Oct 10, 2006 | 03:24 PM
gillbot's Avatar
I used the high temp silver paint, it's lasted 5 years so far. I put it on pretty heavy though.
Old Mar 3, 2007 | 11:20 PM
94blownz281's Avatar
gillbot - how did you cure the paint for your headers? what high temp paint did you use? like where did you get it?
Old Mar 3, 2007 | 11:36 PM
02trns_am's Avatar
What kind of high temp paint are ya using? I've tried a few different kinds on my race car headers but everything just burns off.
Old Mar 4, 2007 | 12:00 AM
djsanchez2's Avatar
Old Mar 4, 2007 | 01:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Wow! From the grave!
Old Mar 4, 2007 | 01:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Probably used VHT paint.
Old Mar 4, 2007 | 01:17 AM
RA4926's Avatar
i used high temp on my 4 wheeler muffler, like 2500*. can said i had to bake it on so i used a propane torch lol. worked but it was a HUGE PITA.
Old Mar 4, 2007 | 12:24 PM
02trns_am's Avatar
I've tried that VHT crap and it burnt off before the motor even warmed up what about that paint for grills? like somebody mentioned above...
Old Mar 4, 2007 | 09:14 PM
thing bout that is you need to cure the paint,ya know heat it up before you bolt them to the motor. i have had autozone high temp heat on my y-pipe for acouple years and i never cured it and it has never flaked off even whe ni blew my head gaskets and cover over heated at 130mph . my headers baked off though alittle and i wraped them but i want the clean look now.
wonder how good powdercoating would last on headers?
Old Mar 9, 2007 | 11:15 PM
gillbot's Avatar
I used generic walmart high temp paint and let the car bake it on as it idled, they still look good after ~5 years.
Old Mar 10, 2007 | 09:58 AM
now is this the BB grill paint at walmart? when you say you sprayed it on heavy did you use only one can or two? thanks
