coil relocation
Old Oct 11, 2006 | 06:19 PM
Country Boy's Avatar
Senior Member
Default coil relocation
Let me see your coil relocation setups. I want to move mine. Can you get 90* plug boots for our cars?
Old Oct 14, 2006 | 07:17 PM
cvman's Avatar
I'd like to see some pics, as well.
Old Oct 14, 2006 | 07:52 PM
Tainted's Avatar
thunder racing has a kit, so does katchet i think
Old Oct 14, 2006 | 09:28 PM
parbreak's Avatar
I have the TR kit:
Bryan
parbreak
Old Oct 14, 2006 | 09:49 PM
Z28_DAD's Avatar
im slowly working on mine, im polishing the valve covers first, then making my own brackets and getting LT1 wires
Old Oct 14, 2006 | 11:12 PM
bichin95redta's Avatar
I wanted a set of custom valve covers from Nasty Performance. After scoping out under my hood, I'm not so sure I'll be able to relocate my coils with an existing kit...I'll probably have to fab something up. I was thinking about relocating them on the wheel wells, but with my shock tower brace, and the way the throttle cables are routed on a T/C-equipped car, I don't think I'll have the room.
I've heard of kits that relocate the coil packs under the cowl, and this would certainly get them out of the way, but I've heard that this set-up, due to the longer plug wires necessary, reduce spark output. I'm not sure how true this is, but I'd like to know for sure before I decided to spend the money on custom valve covers, and a coil pack relocation kit.
BTW....parbreak, that's a bichin' lookin' set-up you have there! Just a quick question; it's hard to see in your pics, but how are you managing crank case ventilation?
Old Oct 15, 2006 | 06:20 AM
parbreak's Avatar
LS6 PCV conversion.
Old Oct 15, 2006 | 07:54 AM
EPP's Avatar
EPP
Smile
As far as total performance goes, you do want the coil wires to be as short as possible. The kits that raise the coils up off the valvecovers seem to be the best comprimise. Katech and Nasty both offer this style, possibly others as well. Bob
Old Oct 15, 2006 | 10:13 AM
parbreak's Avatar
What about using the 10.4 mm wires. That should take care of the longer wire issue. Same concept as relocating batteries to the trunk area. You need to go to a much larger diameter cable to avoid the voltage drop.
