Help with Header install
Old Oct 11, 2006 | 09:27 PM
99Transamls1's Avatar
Default Help with Header install
Okay I am installing some pacesetter Lt's with ory and I hooked them up. My question is the two front sensors (that went in front of the cats) has places for them but there isn't a spot for the other two sensors (that usually would go behind the cats.) Did I get the wrong set sent to me or do you just not use them since I have no cats? Thanks
Old Oct 11, 2006 | 09:54 PM
00HARDZ28's Avatar
Uhh we have a BINGO. You have the Y pipe WITHOUT the cats thats why they call it" OFF ROAD USE ONLY " Becuse on the streets EPA wants you to have cats.Where do you live ???? The only other thing you can do is get them deleted from the system. I would also get the Air/Egr to while your at it. Or you can get 02 sims that will make the comp think there still there but they some times dont work on emmisions test. So where do you live. Hope this helps.
Old Oct 11, 2006 | 09:57 PM
Fibbado's Avatar
Find a tuner....
probably about 45-50 bucks to have them tuned out for you... compared to however much o2 simms are.
Old Oct 11, 2006 | 09:58 PM
JKDZ28's Avatar
You'll only be using the front 02 sensors.
Old Oct 11, 2006 | 10:00 PM
blkbird's Avatar
Get the corvette rear 02's to use for your front ones and you will be ok and use some simms for the rear ones or you could get the rear ones tuned out....
Old Oct 12, 2006 | 07:31 AM
JKDZ28's Avatar
Old Oct 12, 2006 | 08:08 AM
O okay thanks, I thought that I would probly have to get them tuned out. And I live in Arkansas (no emissions at all) I swear some people here don't even have Head lights or tail lights . Thanks
Old Oct 12, 2006 | 07:55 PM
JKDZ28's Avatar
WOW! I doubled posted and it showed up like 10 hours later lol
