weld exhaust components together?
Old Nov 6, 2006 | 09:11 PM
The Professor's Avatar
Default weld exhaust components together?
i'll be getting LTs and an ORY to go with my gmmg. it's going to be my permanent setup. is there any reason i shouldn't get everything welded together?
Old Nov 6, 2006 | 09:19 PM
Snuffles's Avatar
I highly recommend you don't get everything welded together.
Because you will take it apart sometime and then you're fawked.
Welding the pieces together while they are on the car will be a PITA.
And it will be difficult to weld all the way around the pipe, which means a leak is possible.
Why not just use band clamps? ... they're cheaper too.
Old Nov 6, 2006 | 09:52 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I certainly wouldn't weld to my headers.....
Old Nov 7, 2006 | 07:56 AM
DirtyJohn's Avatar
I wouldn't weld @ the headers.
Maybe weld on some flanges so in the future you can adjust the headers if your doing something like heads.
Decent band clamps are also good enough I would think.
Old Nov 7, 2006 | 08:04 AM
BIG_MIKE2005's Avatar
I wouldn't weld to the LT's. I would band clamp them there. But I would get the ORY fitted & then welded. Then you can use band clamps on the I pipe & off the collectors only. This can save you a little ground clearance & is easily removable.
Old Nov 7, 2006 | 08:08 AM
blkbird's Avatar
I got band clamps around the headers and a flanage connecting the Y and I-pipe together.
Old Nov 7, 2006 | 08:13 AM
jamesSS's Avatar
im not sure if this was a rumor, but i have heard welding the parts together will also eliminate some of the rasp, especialy since you are going no cats. i would weld it, but thats just me.
how bout a sound clip when your done...
Old Nov 7, 2006 | 08:29 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you ever do a head swap...get ready to bust out the sawzall.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Step away from the crack pipe. How is that going to get rid of rasp?
