02 sensors and ses light
Second, running with no cat on one side will probably cause the SES light to stay on...you're going to have to get a tuner to tune that out of your computer if you want to stay in that configuration.
Lastly, I wouldn't run just one cat in the ypipe, that is going to throw off the backpressure and not be good for performance. If you are going to get rid of the cats get rid of the cats, but I would buy high flow cats and run those because they won't cost you very much hp and they would sound better than ory and get rid of any gas smell you might see with them off.
So the point of all this is, if you remove a cat, even just on one side the PCM thinks you got a bad cat, and throws an DTC code (and turns the SES light on).
So you have three solutions:
1) have a cat put back on (which you said you did not want, so:
2) a number of our sponsors sell what is called an 02 simulator (or o2 sim for short) these take the place of the post-cat o2 sensor and trick the computer into thinkig a functioning cat is still there. or
3) have the post-cat 02 programmed out by someone with tuning software.
Edit: and like was said above, don't run just one cat, run either both or none.
Running rich, will that foul the o2 sensors or cats after some time?
