code P0430...need help
Old Dec 30, 2006 | 08:50 PM
highheat99's Avatar
Default code P0430...need help
waht would be causing me to get this code on my car? first time tonight just normal driving. thanks
Old Dec 30, 2006 | 10:42 PM
Proud2bSS's Avatar
I assume that you have catalytic converters still on the car?
The P0430 is the classic bank2 (passenger side) catalytic below threshold code.
Either your passenger side cat has gone bad, or the o2 sensor (the one after the cat) has and issue.
How many miles on the car? I believe that the cats are warrantied for 50,000+ miles.
Old Dec 30, 2006 | 11:45 PM
KrazyDan's Avatar
I have the same code. Just a pain in the ***. put some black electrical tape over the check engine light
Old Dec 31, 2006 | 12:04 AM
98camaroLS1M6's Avatar
You can shut that code off for good with hp tuners, but if you want to keep cats(if they're on the car, most likely bad) can get new stock ones under warranty (8/80000mi).
Old Dec 31, 2006 | 02:18 AM
highheat99's Avatar
i just had kooks lt's and high flow cats put on about 1,000 miles ago. there are 59,500 on the car. 2002 z28.
Old Feb 3, 2007 | 01:12 AM
highheat99's Avatar
t t t
Old Feb 3, 2007 | 02:00 AM
Proud2bSS's Avatar
I am thinking either a bad o2 sensor for that 'side' or due to the the hi-flow cat having an issue?
Old Feb 3, 2007 | 04:33 AM
WS6Drop's Avatar
Its the highflow cat causing the problem. I had the same problem with my catted Y and just tuned them out myself. You could also get 02 sims and see if that works.
Old Feb 3, 2007 | 09:22 AM
highheat99's Avatar
the place that did my tune said they will turn the code off for good. is this possiable? thanks
Old Feb 3, 2007 | 09:36 AM
dpw41285's Avatar
yes, the will delet the MIL which will shut of your rear o2s. youll be fine and no more codes.
Old Feb 3, 2007 | 11:24 AM
Proud2bSS's Avatar
Do you have a hand held scanner tool available to clear the code? Another quick diagnosis would be to swap the rear o2 sensors (pass side to driver, driver to pass side) then wait for the code to reappear and see if the p-code switched banks (sides). At least then you would know that it is not the sensor....just a thought.
Old Feb 3, 2007 | 12:07 PM
Craig91's Avatar
I had the same code...took out the rear o2's and replaced them with simulators. Hasn't come on since.
