Help!
Old Jan 15, 2007 | 04:31 PM
02Z28Chevy's Avatar
Default Help!
my car wont engine break...acceleration is good it pulls hard. ive had the car for lil over a year now and ive got a hurst short throw,LCA's,air intake,flowmaster cat back,let me try to clarify....say im running 2000rpms and in 4th i can drop it into 3rd and say it goes up to 2500-2700rpms. instead of the car even remotely slowing down its like its rolling in neutral and the car will hold stead at those rpms
Old Jan 15, 2007 | 04:46 PM
blkbird's Avatar
Clutch is slipping....
Old Jan 15, 2007 | 06:04 PM
TheBlurLS1's Avatar
That's what she said...
If you're cruising in 6th at 70-80 and mash the gas, and the engine starts to rev, your clutch is done. Try that. Mines doing it right now.
Old Jan 15, 2007 | 06:32 PM
02Z28Chevy's Avatar
no its not the clutch the clutch is fine shifts fine no problem accelerating just no engine breaking
Old Jan 15, 2007 | 06:36 PM
TheBlurLS1's Avatar
You mean engine BRAKING.
I didn't know WTF you were talking about. Was your car tuned? You can set RPM decrease by speed, maby someone tweaked it?
Mine doesn't slow down very fast if I downshift, but it does slow down.
Brake is the thing on the floor. Break is when a rod comes out the side of the motor.
Old Jan 15, 2007 | 06:49 PM
00454sscamaro's Avatar
maybe you need a tractor trailor, those jake brakes work almost as good as the air brakes.. lol
Old Jan 15, 2007 | 06:50 PM
blkbird's Avatar
I really didnt get what you are trying to say either....
Old Jan 15, 2007 | 10:18 PM
02Z28Chevy's Avatar
my bad on the spelling i just figured the car should engine BRAKE lol. nah its not tuned least to my knowledge when i bought it from the dealer it just had the intake,LCA's,short throw, and cat back exhaust, i just figured when i downshifted it should slow the car down some instead of sounding like its in neutral and im holding the rpms steady at 3000rpms
Old Jan 16, 2007 | 12:42 AM
well quit holding it there, let your foot off the gas.. lol
weird my car slows down pretty good with engine braking.. not very good on the crappy 10 bolt rear though... if in neutral and your foot off the gas do the rpm's drop fast from 3k rpm's?
Old Jan 16, 2007 | 05:34 PM
02Z28Chevy's Avatar
not really the rpms rise and fall slow all together...my sister has a 97 firebird 3.8 and it revs real quick. ima try cleaning the MAF and TB and see if that helps
