Header install...
Old Jan 26, 2007 | 01:50 PM
71-Camaro-98's Avatar
Default Header install...
How many of you have installed your own headers?? Give me some details on the time, difficulty etc. I have heard that it isn't even worth it to try it yourself.
Old Jan 26, 2007 | 02:02 PM
NviouSS's Avatar
i did my own. took me a weekend to do it because i ran out of sunlight and some minor problems. getting the front end up high enough will make it easier when the lt's are ready to go in. investing in a 10mm ratchet wrench is also a good idea. it makes getting the back header bolts easy.
Old Jan 26, 2007 | 02:08 PM
joecar's Avatar
Lift the car high > 24".
Remove spark plugs.
Spray penetrating oil on cat bolts and header bolts.
Do not use air tools to remove header bolts.
Be patient when turning/lifting headers into car.
Use GM header gasket.
Use new header bolts.
Take your time, take breaks.
Move new Y-pipe around so it doesn't hit floor, tunnel, brace.
Remove the heat shields and leave them off.
Remove AIR/EGR plumbing and leave it off.
Pay attention to O2 wiring, don't let any wires touch headers.
Old Jan 26, 2007 | 02:12 PM
RA4926's Avatar
took me about 4 hours by myself installing pacesetters. hardest part was getting the header up into place and bolting them on (all alone). had to cut the casting tab of the block.
Z28LS1camaroguy's Avatar
its not hard at all just takes time, getting the old **** off is the hardest part. the easiest thing to do to get the old stuff off is to cut the y pipe off with a sawzaw, and also an extra set of hands to hold up the new headers with you thread the bolts helps alot.
Old Jan 26, 2007 | 04:25 PM
LILWS6's Avatar
Just did mine and it would have taken me just the weekend had it not goten really cold so i took it to work and finished it a few days later. Ratcheting wrench helps alot.
Old Jan 26, 2007 | 04:44 PM
pro2low's Avatar
im in the process its not too hard just a pain in the ***....i dont take my cars to shops to get work done. its worth doing it yourself
Old Jan 26, 2007 | 04:57 PM
Order 66's Avatar
Not hard to install. it just getting the old bolts off is the problem. They are new cars anymore.
Old Jan 26, 2007 | 05:09 PM
98Camarod's Avatar
I used a lift and air tools so it was pretty easy. I only had a bit of trouble getting the driver side in. I beat the floor board in a little and it slid right in. Take the passenger side coils off and it will be much easier.
Old Jan 26, 2007 | 06:55 PM
pro2low's Avatar
yea i just tried fitting mine in and it doesnt look likes its going to be fun at all!
Old Jan 26, 2007 | 07:10 PM
ryle's Avatar
Do yourself a favor and do the install yourself. It'll save you money and you will get a feeling of accomplishment when it's all said and done! I just did mine like 2 months ago and it wasn't really as bad as I thought it would be. It ended up taking me a total of close to 6 hours, not including breaks. As mentioned before, just make sure that you get the car up high off the ground. After that just take your time. If it takes you a little longer don't worry about it, nobody is going to laugh at you!
BTW 10mm ratchet wrench is a lifesaver and totally worth the cash if you don't have one.
