t-stat or guage??
Old Jan 31, 2007 | 07:34 PM
SSmoken's Avatar
Default t-stat or guage??
ok my t-stat guage doesnt work how do i know if its my t-stat or just my pos guage??
Old Jan 31, 2007 | 07:41 PM
2001NBMZ28's Avatar
Stock temp gauge? Check the wiring/connector/ECT sensor.
Old Jan 31, 2007 | 07:56 PM
SSmoken's Avatar
yes its the stock one, its never worked since ive owned the car and i have had ir almost 2yrs this summer.
Old Jan 31, 2007 | 08:03 PM
TheBlurLS1's Avatar
That's what she said...
Your guage cluster might just be messed up, the sending unit is on the front driver side corner of the driver side head, right next to the exhaust flange. It's brass, screwed in, with a few wires coming out of it. Make sure it's not messed up and dangling, this would not be good.
You car uses the engine coolant temperature to determine MANY parameters governing how the car runs. If the guage is messed up in the car and not reading, that's not that big of a deal, but if the car doesn't know what temperature it's running at, it's a huge deal. Try having the car scanned through the OBDII port and see if it's registering a temperature. If not, you may just need a new guage cluster.
Old Jan 31, 2007 | 08:24 PM
dpw41285's Avatar
do you have heat after the car is on and running and warmed up?? if so then the t stat works. next you need to find out what blur said is it the gauge or sending unit
Old Jan 31, 2007 | 10:19 PM
SSmoken's Avatar
yes i have heat so im guessin the t-stat workes then. Ok thanks for the info blurls1 i'll see what i can figure out.
Old Jan 31, 2007 | 10:30 PM
dpw41285's Avatar
start by checking the sending unit, cheapest first. if the ecu doesnt think the car is warmed up then it will be staying open loop...correct me if i am wrong.
Old Jan 31, 2007 | 10:48 PM
02wS6firechicken's Avatar
A quick way to check to see if the ECT sensor (sending unit) is working is if your skip shift light comes on. The skip shift does not work until the car is warmed up to 170 F. So if your skip shift is working it might be a good indication that the ECT sensor is working. But to be 100% sure I would run by a GM dealership and ask them to connect the Tech 2 (scan tool) to your car and see if the ECT is giving a reading.
Old Feb 1, 2007 | 02:08 PM
2001NBMZ28's Avatar
Is the car a '98? Thinking they have a 3 wire ECT vs. 2 on the '99 and up - one of them is for the gauge only, and why the '98 gauge actually works?
Old Feb 1, 2007 | 02:24 PM
TheBlurLS1's Avatar
That's my belief as well.
Old Feb 1, 2007 | 03:47 PM
SSmoken's Avatar
car is a 2000
