Pre-Install for LT's Getting Ready!
1) Do you guys recommend that when I have the car up on jacks that it should be level or is it okay if the back is hanging 1 foot lower then the front?
2) For the height difference I have 30" inches (2.5 feet) from the ground to the bottom of the car (front of car), is that enough? For the back I have it at 18" (1.5 feet). What do you guys recommend my hieghts should be?
3) For O2 Simulators will these work off ebay for my header install? Im not too sure because it says "These are only to replace the rear two sensors and not the front ones!" I just want to make sure im grabbing the correct ones.
http://cgi.ebay.com/ebaymotors/1996-...spagenameZWDVW
Those are the O2 sims you need, and that's Speed Inc. selling them (sponsor), so the eBay link is OK.
And yes im going to have extra blocks under the tires just for extra security.
I get a little paranoid.
1. I had my transmission out to replace the slave cylinder. I really don't think this helped as much as you would think. Maybe it did.
2. I took off the heat shields on both sides of the car the one on the driver side that has the stainless clutch line going thru it and the one on the passenger side that the stock cat is under.
3. I unbolted the steering shaft.
4. I also removed the coils from the passenger side. Adds a ton more room for your arm to get at the manifold bolts. Didn't have to remove them on the driver side. Also didn't remove my spark plugs. Although I will admit the transmission being out did allow for me to see enough to keep from breaking them. You should most likely remove them.
Both sides just slid right in. At one point though the passenger side looked like there was no way it would get in there, then I just took a second twisted it real slow in different directions and boom it when in there like I'd done it a million times.
I had stock stuff out and new long tubes in and torqued in about 3 hours. Soaking the lower exhaust bolts that you will need to remove in PB worked great for me. I sprayed them and let it sit for about 5 min everything came apart as easy as you could expect. Cheater bar was needed.
