o2 sensor is throwing a code!
Old Feb 10, 2007 | 02:38 PM
mangus2k1ws6's Avatar
Default o2 sensor is throwing a code!
i have a 01 trans am ws6 with longtube headers and a catted ypipe, it also has a hptuner tune.....this last wednesday i had it inspected for pa inspection and it passed .....but when i picked it up the service engine light was on. i was thinking maybe whatever they did could have thrown it out of wack and maybe a retune co do it......i did hook it up to a obd2 reader and the codes were for a 02 sensor circuit malfunction. please let me know what it could be.
Old Feb 11, 2007 | 02:13 AM
BriancWS6's Avatar
What bank and sensor was it? What mods do you have?
Old Feb 11, 2007 | 02:24 AM
staringback05's Avatar
you could simply just have a bad o2
Old Feb 11, 2007 | 08:39 AM
it threw a po135 code and it said bank 1 sensor 1....but i also had a pending po135 and po155......my mods are just lt headers, catted ypipe, loudmouth1 exhaust, hptuner tune, and pro 5.0 shifter. i do not have a egr on now since i had my headers put on
Old Feb 11, 2007 | 08:40 AM
how could it go bad after going through inspection?
Old Feb 11, 2007 | 08:47 AM
jam01's Avatar
first off be glad it just passed inspection. parts go bad, its part of owning cars, especially when you start modifying.
Old Feb 11, 2007 | 02:43 PM
BriancWS6's Avatar
Bank 1 sensor 1 is the driver side pre-cat. Time for a new one man.
Old Feb 12, 2007 | 12:23 AM
how much do they usually cost?
Old Feb 12, 2007 | 09:03 PM
BriancWS6's Avatar
About 50-60 bucks each. I have had good luck with the Bosch ones. I use PN 13111, it's the vette rears, it is longer and doesnt require the extensions that you have to use with longtubes, and it has also been said to have a hotter "heater" in it, so they get to temp faster, which helps when you have longtubes cause the O2s are located further downstream. I would replace them as a pair. Damn what run-on sentence
