Which should i get????
Old Feb 11, 2007 | 04:17 AM
JeaneGrae's Avatar
Default Which should i get????
The ls6 intake with egr provisions or the one without? Any pros and cons for one over the other?
Old Feb 11, 2007 | 04:32 AM
SatanzWS6's Avatar
first of all, if you go with the one without egr, you will need to get rid of the egr system. that intake will also keep your engine bay cleaner and you wont get all that hot, unburned gas run back through the intake. if you go with the other intake, you have the option of keeping the egr or getting rid of it and plugging the whole. its all up to you. id go for the one without the egr. just my .02 cents.
Old Feb 11, 2007 | 04:44 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ditch the EGR, get the codes turned off, and have a clean(er) engine bay.
Old Feb 11, 2007 | 06:59 AM
Red99TA's Avatar
I think the obvious question is do you have to pass a sniffer for emissions in your state or not? If so then I would keep the EGR as it's only purpose in life is to get you to pass emissions.
Old Feb 11, 2007 | 08:43 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not in H-town he wont.
Old Feb 11, 2007 | 04:01 PM
RevGTO's Avatar
Pontiacerator
The sniffer won't be a problem, it's the visual (like in CA) that will kill you.
Old Feb 11, 2007 | 05:25 PM
Red99TA's Avatar
Actually EGR reduces the NOx number which is one of the things the sniffer reads. It is possible to pass without EGR but it just reduces your chances without it. Also, CA has visual and sniffer. Isn't it nice having your car registered in KS (no visual or sniffer period!!)...it's where my T/A is registered too
Old Feb 11, 2007 | 07:23 PM
RevGTO's Avatar
Pontiacerator
I know ... one of the reasons I took the transfer here from my native CA is to escape all the hassles regarding smogging my cars. Back then, I still had to smog my 69 GTO. KS isn't the most glamorous place in the world, but you have so much more freedom than in CA. You remember what America is supposed to be all about.
I think the vast majority of cars pass sniffer no problem with EGR delete.
Old Feb 11, 2007 | 07:28 PM
Red99TA's Avatar
ahhhh, I miss the midwest...damn military!
