TSP True Duals.
You like them?
What muffler do you have?
Anybody with a lowered car running it?
Do they hit your floor board at all?
Thanks
I like them.
Moroso Spiral Flows (clip in sig)
I am not lowered but I will not be lowering it much when I do, I'll do the heater hose mod on the back and Koni SAs on the front, nothing more than an inch total.
-J
The only downside (this could be with most any true dual setup) is that I am starting to get some vibration from the interior. I was actually fixing to post a thread to see if anyone else has this problem and what they did to fix it. I wonder if a different pair of mufflers would do the trick since I am thinking that it is caused by the drone of the muffler itself...it only happens sometimes at idle or in a low rpm range...
I like them.
-J
-J
I installed them on a lift then lowered the car and placed a jack under the X. I got a great deal of clearance this way. I could, and am still considering, lowering the car.
I get comments atleast once a week on how good the car sounds (oh and the 6 coats of zaino help get it noticed too)
https://ls1tech.com/forums/generation-iii-external-engine/645326-xs-lt-s-tsp-td-s-pics.html
