deleting traction control
Old Feb 15, 2007 | 05:57 PM
DSRCAM's Avatar
Default deleting traction control
i cant delete this traction control please help i have a 98 z what wires do i need to cut??
Old Feb 15, 2007 | 06:11 PM
Mark98SS's Avatar
A lot of guys pull the ABS fuse.
Old Feb 15, 2007 | 06:39 PM
dpw41285's Avatar
what if a man wanted his breaks still. i think there is a diode you can put in there so when you start the car its off, then you can turn it on with the button. Reverse of what it is now
Old Feb 15, 2007 | 06:41 PM
dpw41285's Avatar
or you could pull the switch out and short out the wires behind it so its perm off...that should be pretty easy if u can tell which wire goes to which (open and closed ciruts)
Old Feb 15, 2007 | 07:30 PM
2 SSlow's Avatar
or you could buy the ABS/TCS delete form SJM Enginering and do it right, and drop a couple pounds too.
Old Feb 15, 2007 | 07:44 PM
DuronClocker's Avatar
From earlier today or yesterday.. https://ls1tech.com/forums/generation-iii-external-engine/658946-traction-control-delete-keep-cruise.html
Has some useful info for you. Can just pull the connector off the TCS module.
Old Feb 15, 2007 | 07:58 PM
jam01's Avatar
just use a hammer
Old Feb 15, 2007 | 08:00 PM
jam01's Avatar
actually there is a module you can buy, it reverses the switch.
Old Feb 15, 2007 | 09:33 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Originally Posted by jam01
just use a hammer
CORRECTION...."A Hammer Module." ...
Old Feb 15, 2007 | 11:30 PM
schultzsj's Avatar
I just unplugged mine as suggested by someone else on the board. The plug is right by the unit on the passenger's fenderwell.
I sometimes hook it back up if someone else is driving my car - it only takes 5 seconds.
Steve
Old Feb 16, 2007 | 09:57 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
you're brakes will still work, it'll just be minus the ABS system. the actual downfall from doing so, is if you ever got into an accident and the insurance company found out that you made your ABS not work, they won't pay for the damages.
Old Feb 16, 2007 | 11:23 AM
ShevrolayZ28's Avatar
Are you sure on that? I mean, in my state functional ABS is not required to pass safety inspection. The insurance company wouldn't have a leg to stand on IMO.
Old Feb 16, 2007 | 11:29 AM
Jon5212's Avatar
+1 on that
Old Feb 16, 2007 | 04:19 PM
Bad30th's Avatar
Steve
I have heard that this will only disable the traction unit and the car will still pull timing and fuel when it senses the wheels spinning.
Does anyone know for sure if unplugging the harness on the unit disables TCS/ABS in the PCM as well ?
Rob (Bad30th)
Old Feb 16, 2007 | 04:32 PM
presto_z's Avatar
it can be tuned out..
i wanna totally delete the entire setup so my engine comp. looks less cluttered
Old Feb 16, 2007 | 06:24 PM
BLK02TA's Avatar
Ya how do you delete it so the dam light isnt on.
Old Feb 16, 2007 | 06:37 PM
LT14MULAWS-6's Avatar
please dont tell me u guys are seriously disableing your TCS that has can be turned on and off whnever the hell u want through a factory switch?!?!
unless theres some sort of TCS thats always on and cant be turned off............people who do this dont deserve to be in an f body
Old Feb 17, 2007 | 08:05 AM
Read my post in the thread that I linked. Most of us deleting it just don't like how it looks under the hood. I'm willing to pay the $40 for new cables to get rid of it completely. My nitrous solenoids will look factory installed because they fit perfect in that location
Old Feb 17, 2007 | 08:39 AM
sorry IMO you simply (and n e one else whos stupid enough to do this)do not belong in an f body, this is the exact type of little kid **** one must look for when buying one of these cars used
Old Feb 17, 2007 | 09:14 AM
My last F-body did not have TCS from the factory ('88 TA). The car is way too far gone to sell to an average buyer and I do not intend to sell the car advertising that it has a working TCS system obviously, if I am to sell it at all. I don't see the problem in properly deleting (using GM parts as if the car did not come optioned with it) the TCS system?
