What else to do (bolt-ons)?
Another goal of mine is to make the car exactly identical at the track as it would be on the street, so nothing you change at the track. For example: no suspension you adjust at the track, no taking off the muffler or air filter, and no taking out the spare tire, and no nitrous since that is something you don't always have, etc. Something like taking out the back seat would be fine since I can safelt do that under normal driving circumstances(that why no spare tire removal). I want it to be purely like it will be on the street 100% of the time, except traction of course, because I'm getting some drag radials/slicks this spring and I will use that power for the launch while i'm there anyway.
You can see what I have so far in my sig. down below. I went to the track for the first time ever this fall and ran a 13.1@106 on the stock Eagle F1s that are getting kinda low on tread (~24k miles). That ET was without the ported TB and LS6 manifold too. This spring the first thing I am going to do is get a 3200-3600 stall torque converter and some drag slicks/radials to go with it.
Now my question is, in my quest to make this car as fast as I can, EXACTLY like it would be on the street(except slicks), what else should I do? I know there's an underdrive pulley, but other than that I am up for suggestions. I am hoping to get below 12.5 as far as possible without going to a cam or power adder yet. Thanks!
Oh also, I would like to keep the 3.23 gears I have so I'm not going huge rpms on the highway since I live about 10mi out of town on a highway so the majority of the actual miles I drive are there. Anything else is fine for suggestions though. Thanks again.
As far as suspension, LCA brackets, PHR, LCAs (optional), would all be mods that will stiffen up the slack in the suspension, and help your launch, but also be fine on the street.
. Trending Topics
3200-3600rpm stall converter
Drag slicks
Meziere electric water pump
SLP or ASP underdrive pulley
Possible change to x-pipe
Possible aftermarket MAF(do these do anything at ~350rwhp?)
After all the stuff is in, a Speed Inc. full dyno tune
All that stuff together should be about $3300, or $2500 without the x-pipe and MAF. Only two questions now; Do aftermarket MAFs do anything? I read an article in GM Performance I think where they got just under 3rwhp/tq with the SLP 85mm MAF. And how loud would the X be with Flowmasters compared to my ORY and Hooker? Thanks for all the help guys.
verter
UD pulley
Xpipe
Tune
Are the only things I would suggest from that list. You don't need the MAF or electric water pump. The slicks, verter and tune will be your best options as the rest of the mods are okay but not needed for your power level.
How much does everything you need for a mild (somewhere about 230/230 I'm thinking) cam swap cost? I think I can probably get all of these things done this spring/summer if I work a lot, but I'm not sure what everything for a cam costs. Without the cam or shocks it should be about $1750 so far.
Cam swap you need
- cam
- pushrods
- springs
- retainers
- ported oil pump (recommended)
- install kit (recommended if doing youself)
- timing chain
- install cost (if not doing it yourself)
- tune ($400)
Price all those things out and that's how much it would be for a cam swap.
