View Poll Results: INTAKE??
LINGENFELTER WEIAND INTAKE
2
2.99%
GM LS6 INTAKE
51
76.12%
BBK INTAKE
3
4.48%
PROFESSIONAL PRODUCTS INTAKE
11
16.42%
Voters: 67. You may not vote on this poll
another intake ???
Old Mar 19, 2007 | 07:48 AM
brad8266's Avatar
Originally Posted by taintedmeat
I think plastic was around before the ls1 was manufactured
Old Mar 19, 2007 | 09:54 AM
Reject's Avatar
Originally Posted by 5_02ls1
they used metal because thats all they had
i'm pretty sure all of the manufactureres would have used plastic cuss of the 40 pound difference to try and lightent up their cars if they could have gotten away with it. they had to be metal to heatsink the fuel going threw the runners to vaporize it. in cold winters fuel is harder to ignight, so you heat it up and get it to a tinier mist to light up, now flash forward to today....we have injectors taht pulse longer and atomize the fuel better for cold winters. theres no fuel that runs threw the intake runners... we dont need the metal ones, all they do for us is add extra weight, and dead weight is womp womp. fuel economy goes down slighty, and in todays world. we all want 600 hp cars and still want like 50 mpg, we try and lighten up the car any little bit.
man i hope i made sence, it's to early
Old Mar 19, 2007 | 11:32 AM
lsx24's Avatar
Go with ls6. Other have yet to be proven to make more hp. ls6 is proven. That, and a ported tb and you are good to go.
Old Mar 20, 2007 | 12:35 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
heat soak is not an issue that is worth crying about. LS6 is all you need for any N/A stock cubed LS1.
Old Mar 20, 2007 | 03:30 AM
avengedws6's Avatar
I have the BBK intake with a S2 tb, and I love it. I noticed an gain in torque and power. Probobly not alot without a tune but still noticeable, and it sounds so much more alive under the hood now. Even with the stock tune, it responds with no hesitations.
Old Mar 20, 2007 | 01:50 PM
lastcall190's Avatar
I did a 78MM fast ported to an 85MM with a Professional Products TB and I have about $500 into all of it
...you got a stupid deal At least we all got a good bit of info from Tony M in that thread tho...
-J
Old Mar 20, 2007 | 02:29 PM
01sscam's Avatar
Man-Crush Warning
If you won't do the FAST 90/90, get the ls6 and port the throttle body.
Old Mar 20, 2007 | 03:14 PM
marv's Avatar
<- voted for LS6 and P&P stock TB...made the numbers in my sig on a H/C setup using the LS6 and a Bo White stock TB...
Worked great for me...
Old Mar 21, 2007 | 09:00 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
i thought it was made of some composite type material so it doesn't melt onto the heads...?
Old Dec 30, 2007 | 11:53 PM
Emoney97ss's Avatar
do people that go with a sheetmetal intake have heat soak problems? i've been going back in forth between the fast and the pp 96
Old Dec 31, 2007 | 02:51 PM
Asmodeus's Avatar
I voted the PP manifold, but get it ported and port matched.
Old Jan 2, 2008 | 06:23 PM
  #32
Brads LS1 02Z's Avatar
LS6 Intake Manifold with P&P TB
Old Jan 2, 2008 | 07:00 PM
  #33
Asmodeus's Avatar
Thought of something else, you could go with a ported LS2 intake, I think you have to change over the fuel rails with it, but you can put a 90mm tb on that too. Flows like a fast.
