Best Spark Plug change
Also, do you have to remove the headers for a spark plug change? Can you go from the top or bottom?
Once you can't turn it by hand any more, reach back the same way with the spark plug socket and get to wrenching. The right ratchet and extensions will make the job easier. You just have to see what works best for you. After my valvespring swap last year, I had the plugs, wires and coilpacks back on the motor in under an hour working at a reasonable pace - not rushing. Don't forget the di-electric grease and anti-seze. Their good cause they last a while and Im sure they are ok on the resistance side of things, but there are better wires out there. If your gonna take the time to do it, dont you want to put the best you can get? There is a thread on here somewhere, where somebody did an independent test on the resistance of a handful of plugwires. Try a search, and find the best one for you.
