I screwed up!
I guess I should wait for an answer or learn what I am doing. Now what?
I took the water pump off and the remaing bolt end was loose. I unscrewed it with my fingers.Question: None of the other bolts broke and there doesn't appear to be any other damage. Am I good to go with a new bolt? Or did my trying to tighten them too much cause any other problems? Also, should I go with factory bolts? See this link for the history
https://ls1tech.com/forums/generation-iii-external-engine/664805-torque-question.html
Jesus christ man are you on crack? These main cap bolts on THIS BITCH don't even need 132 ft-lbs....
JK, they actually might...
Here's the link if you've never seen this thing before...
http://people.bath.ac.uk/ccsshb/12cyl/
You found out the hard way why, lol. At least it came out easily.
