blew a hole in my primary
Old Mar 8, 2007 | 03:45 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default blew a hole in my primary
so coming home today i got it a wee bit and i blew a hole in my cylinder 1 primary. i have headman stepped lts painted there about 1 year an a half old anybody else every done this
Old Mar 8, 2007 | 03:58 PM
LS1Tech Sponsor
yea so **** hedman they told me the only way to warrenty the hedders is if i send them to them to be inspected to make sure it wasnt my cars fault which still runs fine. i was like well i patch it so i could drive it and hes like well you voided the warrenty complete bs im so pissed
Old Mar 8, 2007 | 04:02 PM
Tainted's Avatar
should have gone with e-bay headers!
Old Mar 8, 2007 | 04:08 PM
LS1 ACE's Avatar
that sucks man. i guess now you have to weld a piece on there or go with some Pacesetters. i remember reading a thread about some guy blowing a hole in one of his headers primaries also. i just don't remember what brand they were. so it does happen, but it is just not common.
Old Mar 8, 2007 | 04:09 PM
LS1Tech Sponsor
actually i just read that post and his were lg's but now that i think about it after reading his it was were my air fitting was now it is not
Old Mar 8, 2007 | 05:48 PM
Red99TA's Avatar
WTF...did the metal just fail in some random spot or is there a weld bead or something where it blew out? That's ridiculous either way. I don't see how the exhaust can cause that (it's not like it's causing major pressure inside the primary...maybe it was the multiple heat cycles combined with the "mild" pressure from the exhaust at higher rpms).
Old Mar 8, 2007 | 06:57 PM
Hard Core Z28's Avatar
Was it one of the primaries with the air or egr tube on it. Was it blocked off? If the tube was blocked off then it is common to happen.
Old Mar 8, 2007 | 07:20 PM
TheCarKid's Avatar
it happened to me on my pacesetters but it was where the A.I.R. tube is welded to the primary. Just ordered some new ones without the emissions stuff and coated so i highly doubt it'll happen again.
Old Mar 8, 2007 | 09:59 PM
LS1Tech Sponsor
yea it was where the air fitting was
Old Mar 8, 2007 | 10:02 PM
ArrestMeRed99Z28's Avatar
+1 E-Bay headers
AJ
Old Mar 8, 2007 | 10:59 PM
TheBlurLS1's Avatar
That's what she said...
Did you buy the headers from a vendor or directly from Headman? I'd go to the vendor, and let them deal with Headman, they usually have a little more stroke.
So when they fail, there isn't even anybody there to tell you to **** off!
Old Mar 8, 2007 | 11:01 PM
Sudz's Avatar
one of my pacesetters did this. I just ended up buying qtp race style
Old Mar 8, 2007 | 11:09 PM
LILWS6's Avatar
i think someone had a set of kooks blew of an air fitting as well my air is hooked up so i hope mine don't do this down the road
Old Mar 8, 2007 | 11:20 PM
TheBlurLS1's Avatar
It's happened on nearly every header I've seen at least once. The LS1 is just too badass to keep the exhaust contained! A guy blew his Kooks nameplate off a while back, and George from Kooks came in and offered to replace it IIRC.
For every case of someone having a bung blow off, there's 100 others who have no problems, block-offs or not.
Old Mar 9, 2007 | 08:04 AM
If you had it blocked off i highly doubt hedman will warranty it for you. Like blur said, every header has had this issue when they are blocked off. Thats why im getting race style headers and wont have to deal with that.
Old Mar 9, 2007 | 08:19 AM
LS1Tech Sponsor
im not gonna worry about it its patch im getting ready to get 6 oh manifolds and build a turbo kit so i dont care anymore
Old Mar 9, 2007 | 02:45 PM
Blacker's Avatar
I had a set of Hooker LT's and the same thing happened with my right side AIR tube. I ended up ditching them and bought QTP Race Headers.
