switching front and rear o2's?
Jarett
Have you driven the car much? It will probably get much better after you put some miles on it.
The plugs are pretty easy with LT's. I remove my rear 2 coil packs on the passenger side, and do the #2 #4 and #6 from the top. You can get #8 from the bottom easy as pie, just watch out for the heat shield, people have bled to death under their cars from those bastards.
Driver side is cake.
They are pretty resiliant, so it probably burned it off. Do you have a friend with an LS1 car? You can run his O2's to diagnose, so that way you don't have to waste money chasing a problem.
no one around me right now has an ls1 so swaping the o2's wont work. ill just go buy some new tr55's tomorow or something, then try it out when im off work this weekend. Thanks a ton for your help blur. you are always there with an answer.
Jarett
