AIR Removal with PICS!
What bobbyd was saying is you can get the air pump code permanently removed. Then you should pass.
Didn't mean to be Johnny Raincloud, and your car is really clean - just kind of a "so you know" kinda deal
I will be installing my race style QTP's and ORY so I have no need for the Air system in my car. Engine bay looks better without it for sure.
Anybody have suggestions on how to remove this? Thanks
Here is a pic of the solonoid, on the drivers side. I unbolted the connector, unplugged it, and pryed the solonoid off the mounts. I think one of the mounts bolts onto the back of the intake, which I was not going to remove.
And from below, the pump in place (some bolts were already removed, but apparently the previous owner did not have the required 10" socket extension to get to the 10mm bolts and undo the bracket. However, taking the pump out of the bracket made getting to the other two bolts easier. The other two bolts are hidden in this pic by the pump.
I'm real nervous when it comes to ripping stuff off the car so this has me a little spooked
