AIR Removal with PICS!
Old Oct 28, 2007 | 10:11 PM
  #101
DFWGrant's Avatar
A couple of questions:
The '02 doesn't have EGR?
Would the AIR system have anything to do with running too rich in lower RPM's/start-up?
It really has very little to do with drivability, right?
Thanks!
Old Oct 30, 2007 | 11:46 AM
  #102
JasonWW's Avatar
Thanks!
GM got rid of the EGR valve for 01 and 02.
What the AIR (Air Injection Reaction) pump does is pump fresh air into the hot manifolds to get the catalytic converters up to temperature quicker to reduce harmfull emisions during the warm up time.
It should not effect drivability.
Old Oct 30, 2007 | 02:49 PM
  #103
Black99CamaroSS's Avatar
I think he wants to know if fresh air on the o2s would make your car run rich.
Old Oct 30, 2007 | 05:00 PM
  #104
Spiewalk's Avatar
Correct me if i'm wrong, I think that the computer actually has a time table for the AIR system just like it does for the EGR. I think while the AIR is on the system has a small time table to correct fuel/spark. I might be dreaming, I know it does for the EGR. Either way the duration of the AIR is soo short, it never runs into closed loop.
Old May 24, 2008 | 04:25 PM
  #105
NJgunslinger's Avatar
Default plug
Originally Posted by 2002BlackSS
Since this thread popped up again, I guess I'll answer my own question. The hose referred to is a very short hose that attaches to the back of the intake manifold. It could be removed, and have the intake plugged, but that's not worth it, so just capping the hose until there's a reason to remove the intake, is customary.
What do you plug it with? Any pics of it?
Old May 27, 2008 | 04:19 PM
  #106
ok I pulled this AIR system out, but when taking out the T-filter or whatever it is on the back of the INtake where the hoses meet I pulled the vacuum hose off whatever it was attatched to the back of the intake. I cant seem to find what it was connected to from the intake to the hose. Anyone have any idea where and what it is? I never "plugged" it up, so not sure what this will affect if I dont.
Old May 28, 2008 | 05:36 PM
  #107
Shockwave179's Avatar
Pulled my AIR system today, this thread was helpful thanks!
Old Jun 26, 2008 | 08:03 PM
  #108
SheaMus's Avatar
Same thing here...what do u do for the 01 nd 02 with this t fitting? plug it up ?
Old Jul 12, 2008 | 07:00 PM
  #109
R1ch's Avatar
I just did mine, I pulled out that 3 way piece and capped off the vaccum line that lead to the solenoid.
Old Sep 23, 2008 | 12:15 AM
  #110
ZMONSTER!'s Avatar
ok quick question
I want to do this but Im worried about my cats. They are high flow type and Im wondering how the air delete would effect their life.
Old Sep 23, 2008 | 06:52 AM
  #111
JasonWW's Avatar
Originally Posted by ZMONSTER!
ok quick question
Not at all. It will just pollute the atmosphere for a minute or two until the cats come up to temp by themselves.
Old Sep 23, 2008 | 08:36 AM
  #112
dutinsss's Avatar
same here. i plugged the hose when i took my air out but a while back i just saw the plugged hose laying somewhere not attached to anything. does anybody know where it hooks up so i can plug it with something?
Old Sep 23, 2008 | 10:52 AM
  #113
ssgunny's Avatar
Hopefully the attachment in the thread I started helps you.
https://ls1tech.com/forums/generation-iii-external-engine/989321-air-solenoid-diagram-questions.html
Old Sep 23, 2008 | 11:31 AM
  #114
dutinsss's Avatar
thanks a lot man! that's exactly what i was looking for. i was feeling all around the back of the manifold to find it. now i just need to cap it off.
Old Sep 24, 2008 | 06:12 AM
  #115
ssgunny's Avatar
No problem. I wish I had it when I took mine off. I followed the ls1 how to site for the LS1 to LS6 conversion and it pretty much only said to BE CAREFUL while removing the intake. If I new what was back there it would have not taken me 30 minutes of LIFTING and slowly inching the intake forward and feeling behind it to see what was there.
Old Sep 24, 2008 | 02:35 PM
  #116
extinctls1's Avatar
I did this when i did my headers this past weekend, my car seems like it is running super rich (Can really smell gas when driving slow). Do i need to plug up the wire that went into the top of the three way fitting? I got the SES light today after driving all week I am thinking that a tune will help all of this out.
Old Sep 24, 2008 | 04:37 PM
  #117
dutinsss's Avatar
removing AIR shouldn't make it run any differently but yea, you should plug all vacuum lines that are open. you probably just need to plug that line and get a tune.
Old Sep 25, 2008 | 08:44 AM
  #118
ssgunny's Avatar
Did you remove the entire AIR system? If so the "wire" (actually it is a vacuum line) you talk about that went from the "T" fitting to the AIR shut off valve (canister) and should have been removed along with everything else.
As far as the gas smell did you mess with the fuel rails?
Old Sep 25, 2008 | 09:12 AM
  #119
extinctls1's Avatar
No i didn't mess with the fuel rails at all unless they got screwed up someone when i was taking off that three way fitting.
Old Sep 25, 2008 | 09:18 AM
  #120
dutinsss's Avatar
you sure it's not just more fumie due to running headers and no cats?
