is the y-pipe hitting the floorboard dangerous
Old 03-15-2007, 04:20 PM
nickdotcom's Avatar
Default is the y-pipe hitting the floorboard dangerous
my y pipe hits the floorboard, but nobody can hear it, i can feel it though. is it dangerous at all? cuz i really don't mind it.
thought maybe it would get the carpet too hot or something on a longer trip.
Old 03-15-2007, 04:48 PM
SLO98Z's Avatar
Not dangerous, but annoying I'm sure
Old 03-15-2007, 04:51 PM
BIG_MIKE2005's Avatar
Nope, can cause false knock I have heard though. Mine does & I'm about to put a piece of radiator hose over it & make a pad like thing to stop it. I know it sounds stupid, but I'm not the only one on here who will have some on my y-pipe. Its the cheapest & easiest fix for the problem.
Old 03-15-2007, 04:54 PM
tuffass's Avatar
YES it will blow up!
Kidd'n... No not dangerous, just annoying.
Old 03-15-2007, 04:55 PM
FireSilverLullaby's Avatar
yeah radiator hose works fine as long as it stays on their. i just need to find out how to secure it between my headers and k-member
Old 03-15-2007, 05:41 PM
00slowredz's Avatar
that sounds like a hell of an idea....i'll buy some rad. hose to get that **** to stop clanking around all the time
Old 03-15-2007, 07:12 PM
02silvaZ's Avatar
i did it too
Old 03-15-2007, 07:24 PM
nickdotcom's Avatar
i read that when i was doing the searching, i think i may do that, they used narrow band clamps to hold the hose between the y and floor board
thanks guys
Old 03-15-2007, 07:36 PM
Breaking Stuff's Avatar
I just wedged several pieces and most of them stayed. There was one spot where they fell out like once a month so I kept extra pieces in the trunk.
Old 03-15-2007, 10:11 PM
Greystar's Avatar
We've got gigantic speed bumps at a few of the shopping centers here and the y-pipe on my Formula hits the thigns every time and bangs the floor pan. I've got the pipes tucked up as far as they'll go too and my suspension is 100% stock. It irritates the hell out of me.
Old 03-15-2007, 10:14 PM
Tainted's Avatar
haha yall woud never guess what I jammed in b/t mine to stop the rattle
an old brake pad...and it works perfect!
Old 03-15-2007, 10:50 PM
RYNO_Z's Avatar
thanks guys
Go ahead and do it. I used just a spare piece of hose laying around the garage and a standard hose clamp to keep it from slipping off. Fixed the problem completely. After swapping out my stocker cat back it readjusted the y a bit and I no longer have the problem.
Old 03-16-2007, 07:34 AM
Well we got some strong wire here at work similar to bailing wire used for hay. I'm gonna run it thru the sides & use pliers to twist the wire until it gets tight & secure. Probably use (2) pieces to help keep it in place.
