98z what coolant to use?
Green coolant will not eat seals and all that that the above poster mentioned.
The experience I have with coolant is that i have been runing green forever and havent had a single problem, they key is to not mix dex and green and to change your coolant often enough.
Plus when a mechanic does flush they typically dont flush the block out fully and if the green and dex mix then it will cause major problems.
But hey whatever man think what you want to. Im not in the mood to sit and argue over coolant right now plus its a topic that has no solid proof on either side so mits pretty much a waste of a discussion.
When you say " Plus when a mechanic does flush they typically dont flush the block out fully and if the green and dex mix then it will cause major problems." makes no sense. If they don't flush the block out fully, than they are definatly mixing the coolant. I run 12 quarts through your system which is usually 4 more quarts than neccessary. This guarantees all old coolant is flushed out. Believe what you want, it's not my car. Just please don't go spreading misinformation on this board if you are not 100% positive. An opinion would have suficed in this case rather than a bold statement like this "Green coolant will not eat seals and all that that the above poster mentioned".
I'm glad you think you right. God bless. I don't want to ague either and refuse to after this.
Im not trying to argue with you, i am just saying what i have seen and there are mechanics that will say they did a coolant flush yet didnt flush the block out hence mixing the dex and green.I am glad you are a mechanic that doesnt do that.
My statement wasnt meant to attack you just stating that using either Dex or green coolant isnt going to hurt anything. I am not spreading misinformation because there is not undeniable proof that green coolant eats up anything, if there is stated proof then post up. You dont have 100% proof and neither do i, lets leave it at that.
And I use that green **** from prestone that is supposed to be compatiable with dex and regualar green.
Just for your info:" In many US and Japanese antifreeze formulas phosphate is added as a corrosion inhibitor. European vehicle manufacturers, however, recommend against the use of phosphate containing antifreeze. The following will examine the different positions on this issue to help judge the pros and cons on phosphate inhibitors.
In the US market, a phosphate inhibitor is included in many formulas to provide several important functions that help reduce automotive cooling system damage. The benefits provided by the phosphate include:
- Protect aluminum engine components by reducing cavitation corrosion during high speed driving.
- Provide for corrosion protection to ferrous metals.
- Act as a buffer to keep the antifreeze mixture alkaline. This prevents acid build-up that will damage or destroy metal engine parts.
"So the bottom line is this, if your car came from the factory with Dexcool®, use Dexcool® for replacement or to top off. If your car came from the factory with standard "green" antifreeze, use that for replacement or to toping off. Case in point, Dexcool® has been known to cause head gasket and water pump failure on some Ford OHC V-8's."
NOTE: Fords don't come from the factory with Dexcool. They come with green and should be replaced with green. Same for GM, they come with Dexcool and should be replaced with such.
My point was that there are others out there that claim dexcool destroyed their seals and stuff. I am not backing that statement up by any means, but just saying what has been said by some other people. i myself have not had any coolant related issues on my car. I just did an engine swap and the water pump was clean as was the old engine. Everythingm seemed fine to me when it was apart.
I checked the bottle again and it says for use in all cars and works with all coolant types and includes anti-corrosion and specifically mentions it works well with aluminum parts.
I've seen damage that dexcool & green coolant causes with my own eyes, it was because it wasn't changed....can't believe GM states that Dexcool doesn't need to be changed for 5 years...lmfao Electrolysis is the cause of metal corrosion....the coolant gets an electrical charge after a while if it hasn't been changed which causes breakdown of cooling system components
