LS6 swap questions
Old Mar 24, 2007 | 04:23 PM
its turbo time's Avatar
Default LS6 swap questions
Alright so i bit the bullet and bought a used ls6 intake yesterday. What are the typical problems or issues that get run into while doing the swap? I've heard some people break the oil sending unit if there not careful. How is this avoided specifically? Also, I've heard that there are ribs on the bottom of the intake that sometimes get removed in order to make room for the coolant lines or something along those lines. Is this step neccesary?
I have a ported stock TB and was wondering if there is anything that could be cleaned up easily on the new intake while i had it off. Like radiusing the intake etc.
The user i bought from said it included all gaskets and a map sensor. Is there anything else that is needed?
I've reviewed the ls1howto.com on how to do the swap and so far these are the only things im still unclear on.
I also tried the search feature but it wasn't working.
thanks to all who respond!
Old Mar 24, 2007 | 07:05 PM
anybody?
Old Mar 24, 2007 | 07:10 PM
Tainted's Avatar
dont break the oil pressure sending unit. the installs easy if youre careful
as for the ribs, they will need to be removed if you dont plan on using the LS6 coolant lines. I didn't use the ls6 lines so we cut all the rubs off with a dremel
Old Mar 24, 2007 | 07:12 PM
ONEBADASSWS6's Avatar
You will have to notch the bottom tibs of the intake with a dremel in order to get it to clear the stock metal coolant lines that run beneath the intake. Other than that it should be a direct bolt on.
Old Mar 24, 2007 | 07:26 PM
where is the oil pressure sending unit? If i follow these instructions http://www.ls1howto.com/index.php?article=5
will i still need to remove the ribs?
is there a way to install without buying the lines that are listed as required in the above mentioned directions?
Old Mar 24, 2007 | 07:36 PM
Tainted's Avatar
you dont need the lines jsut cut all the ribs on the bottom off. the oil pressure sending unit is the thing in the back, jsut watch your brake booster hose and dont ****** on it and you'll be fine
Old Mar 24, 2007 | 09:22 PM
thanks tainted
Old Mar 24, 2007 | 09:58 PM
Tainted's Avatar
if ya get anymore questions feel free to shoot me a pm
