How in the hell do I remove a crank bolt from a longblock that's pulled??????? ARGHHH
Is there a flywheel still on it? take it off and use the two bolts on the end of the crank and a bar method as some have stated. Screw them in as far as you can to keep them for being damaged. (use a grade 9 or 10 bolts)
If you use one of those tools for the pulley, a Cheater bar on it may also be needed.
Then get a breaker bar with the socket and a 3-4" (longer is better, mind was almost 5") cheater bar and put your weight to it..
Make sure you use some grease and washers when re-installing the pulley.. but that is another story for another day.. 1st things 1st.. get it off.
Here's a pic. 1/8"x3/4" flat I think. I put a couple washers to even the outer piece.
I went and bought a 6pt today and hammered on it for about 5minutes and it finally broke free
woot!
Now gotta remember how in the hell to apply the pulley.
Last time I did this was with motor in a 2k WS6 and it went ok.
Now I can't seem to get my puller on grrrrrrrrrrr
searching threads now!
go figure.
Looks like I'll be sending everything to machining afterall. Front cam bearing I can see wear on it, and some copper or brass or w/e it is.
Going to tear it down in total and send it off for cleaning, bore, honing etc...
Anyone have recommendations for shop to do this work in IL or how I'd go about shipping.
Also expected costs for such work?
thx
see pics in thread
https://ls1tech.com/forums/showthrea...08#post6741108
No flywheel on motor so I can't wedge/lock it.
Motor just turns and hisses at me when I apply breaker bar to the crank bolt.
tried a $200 625ft/lb 1/2" impact wrench and it just laughed at me. Barely moved pulled and didn't budge bolt.
Tried to head up bolt for about 1min or so, but didn't want to fubar something really bad
any tips or help would be welcomed. I searched but didn't come up with anything
thx
John
Honestly, try running some fresh oil through your impact right before you try removing the bolt. Also, make sure your pushing hard on the back of the impact towards the bolt. This will make sure all the energy from the impact will be transferred to the bolt. Also, an actual impact socket will hit harder than a chromy (and you reduce the chance of a grenade going off). I've got an Ingersoll titanium 1/2" impact that is supposed to be 1000 ft/lbs in reverse. I've never found a crank bolt it won't remove.
I love my tools and it's sometimes a good excuse to go buy more. I have to have things NOW too, but sometimes you are absolutely right, patience is a blessing. Thx again for your help
John
