ARP harmonic bolt.
Old Apr 2, 2007 | 10:53 PM
BigBenz's Avatar
Default ARP harmonic bolt.
What the hell do i TQ this puppy down to. the search aint working.
part number 234-2503
thanks alot guys.'
im hearing 250 lb tq please dont be true.
Old Apr 2, 2007 | 11:05 PM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by LS1HowTo.com
Seat your pulley back onto the snout of the crankshaft as best you can by hand. If you purchased a longer crank bolt which I *highly* recommend, start threading this in now and pull the pulley on about a 1/4 or 1/2 an inch and remove the longer bolt. Use your old stock crank pulley bolt to pull the pulley onto the crankshaft until the bolt seems to get impossible to turn. Grab your biggest torque wrench and attempt to torque that bolt down to 240lb/ft. I have always stopped at 200lb/ft on my installs and I've never had a problem, so if you can't hit 240 (which I never have), don't worry about it. Now, break the bolt free and remove it.
NOTE: If you did not buy a longer crank bolt, and you are reinstalling the stock pulley, you run the risk of stripping out the first few threads of the crankshaft. This will NOT be fun to fix! Take your NEW crank pulley bolt and thread it in all the way by hand. Torque this bolt to 37lb/ft. Now, we need to stretch the bolt into place. Get your breaker bar and pipe extension, and try to turn the bolt 140degrees past where it is at now, keeping in mind the engine will be trying to turn some and those are degrees you can't count. Again, I always seem to get about 90-100 degrees worth (estimating, knowing what 90 degrees looks like) and leave it as is so don't worry about going crazy here.
Once the pulley is installed, the timing cover should be nice and centered around it, so we can now tighten all 10 of those timing cover bolts. Torque them to 18lb/ft on the bolts you can get a torque wrench on, and just make the others you can't get the wrench on about as tight as those. Reinstall the A/C belt at this time.
I used this method, worked awesome. I don't think you stretch the ARP bolt. Just install the pulley as stated above until you have to remove the old bolt. Then put the ARP bolt in and tighten it down as hard as possible.
Old Apr 3, 2007 | 12:22 AM
BigBenz's Avatar
with the arp bolt? and its not the stock crank pulley. its the ati harmonic balancer. why would i want to use the stock crappy bolt. i stripped the first 3 threads off the crappy bolt on my last car. Th stock bolt is weak. how do i install the ARP bolt.
Old Apr 3, 2007 | 12:30 AM
TheBlurLS1's Avatar
Most people use the old stock bolt to install the pulley, then put in a new stock bolt. The stock bolts are torque-to-yield, which means they are toast after one use. ARP is not, it's a much stronger unit, so that process I posted earlier doesn't really apply.
You need a longer bolt to get the pulley started with or you will end up stripping the CRANK, which is about as bad as it gets. After that, put the ARP in and TQ it down.
Old Apr 3, 2007 | 12:33 AM
Da Swami's Avatar
No, you just use the stock bolt to "pull" the ARP on to the end of the crankshaft until it seats.
Blur is just saying that because it's an ARP bolt you don't have to do that extra "torque to yield" crap.
EDIT: Right, what he said.
Old Apr 3, 2007 | 12:45 AM
BigBenz's Avatar
ahh good point now it makes sence.
Old Apr 3, 2007 | 12:47 AM
getusum's Avatar
Look at my sig.....the only thing you need ..well worth the 40 bucks
Old Apr 3, 2007 | 12:55 AM
BigBenz's Avatar
i dont get it.
Old Apr 3, 2007 | 06:10 AM
vettenuts's Avatar
You guys have all of this wrong. Follow the GM procedure, which is DON'T pull it on with a bolt or you will damage the threads. If you don't have the right tool, make one, its less than $20.
Once the balancer is on all the way with the installation tool, use the old bolt and torque to 240 lb-ft. Then measure your snout setback, it will differ with the ATI pulley. Once you do this, install the ARP bolt with ARP Assembly Lube on the threads and both sides of the washer. Tighten to 190 lb-ft. If you take the ARP to 240 lb-ft, you will likely break it.
Also, I assume if you have the ATI pulley you have measured your interference fit and are between the required 0.0007"-0.0009" interference requirement on the diameter.
Old Apr 3, 2007 | 10:28 AM
405HP_Z06's Avatar
You have a few options when it comes to the method by which you install the balancer. I would recommend the Kent Moore J41665 tool that GM calls out for this. It can be had on Ebay for ~$30. You will need a long bolt like in the picture from Vettenuts to use the tool. You can also buy the installer from hawk618 that works very well. Finally, you can make your own as detailed by Vettenuts.
ATI recommends 240-250 lb/ft as a torque specification for their balancer, whether using an aftermarket or stock bolt. Over the past few weeks, I've installed two ATI balancers on Corvette's with ARP bolts torqued to 250 lb/ft and have not had any issues.
There is a very good installation document here: www.jasperengines.com/pdf/GMCrankBalancer.pdf
HTH
Old Apr 3, 2007 | 11:49 AM
TheBlurLS1's Avatar
Installing the pulley with a bolt is fine and dandy as long as it's a bit longer than the stock bolt. Putting the pulley in the oven for a while also helps.
The threaded rod with washers and nuts is the best option, but it's not completely necessary.
Old Apr 7, 2007 | 10:37 PM
BigBenz's Avatar
this is what i did. i used the stock old bolt to get my new bolt about 7 turns in . The the just took that arp bolt till i couldnt pull it anymore. seems just fine and everything lines up. I was almost standing on the bar lol
Old Apr 7, 2007 | 10:43 PM
Tainted's Avatar
I like his way, short n sweet
Old Apr 7, 2007 | 10:57 PM
KurtRardin's Avatar
Veteran: Marine Corps
I've got a few questions:
1) Is TSP the place to get my cam gasket kit?
2) I need to get the ARP bolt on top of the gasket kit?...so i then have a new balancer bolt and an ARP bolt...right? lol
3) *confused* the ARP bolt is used to get it started...then the stock one tightens it down...then the stock one comes out and the ARP goes back in @ 190lft/lbs???
I think I've heard/read too much about this and I've confused myself pretty good.
Old Apr 7, 2007 | 11:19 PM
Tainted's Avatar
I think I've heard/read too much about this and I've confused myself pretty good.[/QUOTE]
im with him
Old Apr 8, 2007 | 12:24 AM
Grimes's Avatar
here's what i did and it was fine:
-used old bolt to seat pulley - 240ftlbs
-put on arp, and torqued it to 240
I probably only hit like 220, because I am a small Asian guy, but it has had no problems for over 2yrs!
Old Apr 8, 2007 | 01:16 AM
Tainted's Avatar
**** 240lbs... i weight 120lbs 6 foot 2 skinny weak *** pale as milk boy im gonna need some help
Old Apr 8, 2007 | 09:17 AM
KurtRardin's Avatar
so by " seat" you mean its on as far as its goin? Also, you didnt use a longer bolt to get it started?
Old Apr 8, 2007 | 11:57 AM
FU_I_AM_UltraZ's Avatar
thanks alot guys.'
first pass for a crank bolt is 36ft lbs tq. then second pass is 120 or 140 degrees which the total come out to a lot lol... if you have the tool with the degrees for tq. then you'll be fine.
Old Apr 8, 2007 | 05:01 PM
KurtRardin's Avatar
Im still confused. lol
