Gains from ported Fast 90/90?
Well i'm not saying you won't see power you just won't see as much down low. If you are going to leave ur car pretty much stock I would just go with the LS6 intake manifold. And save yourself the money with a LS6 intake I have seen better numbers down low on a stock engine compred too th Fast 90 with a stock engine. I guess you will have to ask urself this question do you want to spend 800 on a Fast 90 intake or spend around 400 for a LS6 inake? You also should buy the 90mm fast t-body which is another 400 too so ur looking at 1200 which you will prolly see 20-35 depending on which setup you go with. If you have the money to spend I'd say go for it, If you don't go with the LS6 intake manifold. Another question you have to ask urself you can spend $1200 on a nitrous system and make a lot more power=). I Did go with a Fast 90 and a 90 Nick williams T-body for my 01 Z06 also put 215 ETP cylinder heads, With a real big camshaft, Underdrive Pulley, Double Roller timing chain, SLP oil pump, Long tube headers no cats, Halltech Stinger, Pushrods, 42 lb injectors, MSD wires, NGK plugs, Ram Clutch, Ram Flywheel, Ram Master, Ram slave cylinder, SLP loud mouth, 315/30/18 BF Drag rad, Had to get the Rocker Stands Machined & Put a 175 Wet Shot of Nitrous on the car Prolly spent around 12K on this project over the winter time just had the car dyno tune made NA 477 RWH & 472 RWTQ on the bottle it made 665 RWH & 652 RWTQ. I saved up the money over the winter time 6 months and dropped ever penny I had into the car because the goal was to go with the setup I wanted by spring time and leave the car alone no more mods the car is done. The point im trying to make is research what you want too do with the Head/Cam Nitrous, Turbo, Supercharger whatever just as long as the setup you pick makes you happy set a budget for yourself and a plan to get yourself to that goal you set then stop spending money on the car before it gets to expensive unless you have tons of money and don't really care. What you have to remember the more performance mods you do too your car the more things are going to break etc etc. You have to cover all the basis when researching what you are going to do too the car. Example if you go with a Head/Cam Nitrous 175 Wet set up say on a 99 Transam you have to remember yeah your going to make good power but you will need a sticky tire too hook up. Now you have a tires too hook up now you may have rearend problems, Torque arm problems it's never ending too doing mods too a car so you need to carefully pick out what you would like too do with the car. Sorry to get way off subject
