Did I install my TB right??
Old Apr 10, 2007 | 09:46 PM
Yahelou's Avatar
Default Did I install my TB right??
I installed a BBK 80mm throttle body last week. I was lookin at it today. The throttle cable seems kind of loose. When I pull on it, i get about 1-2 inches of cable, which doesnt seem right. also sometimes when im drivin it feels like the gas pedal is stuck(I have an auto). How tight should the cable be?? I can take the cable off without even pulling back on the throttle body which doesnt seem right to me?? anybody got any ideas.
Old Apr 10, 2007 | 09:57 PM
SlowazzVette2's Avatar
Its been a while for me but on my 98 Z28 I could only pull the cable off if I pulled the black plate back which opens the throttle blade. So my opinion is no unless things have changed over the years. It sounds like you have to much slack.
Old Apr 10, 2007 | 10:04 PM
DirtyJohn's Avatar
There is a small black box like thingey about 16" from the TB cam, it is a mechanism that will allow you to adjust the tension of the cable on the cam
You release the clip, adjust one way or another and lock the clip back in place.
That's the best I can describe it, and if you go mess with it you will figure it out instantly.
Old Apr 10, 2007 | 10:44 PM
Yahelou's Avatar
Is this what u are tallking about??
how do I release the clip?
Old Apr 10, 2007 | 10:52 PM
DirtyJohn's Avatar
Nope, this....
Sorry, it doesn't look like a box so much does it.
Old Apr 11, 2007 | 01:02 PM
noname024's Avatar
What is this? Is this only on the 01 and 02's? I have a 98 and it doesn't have this. I have two cables. One cable running from the tb back through the firewall and the other one starts right next to the tb and I don't know where it runs to.
Old Apr 11, 2007 | 01:46 PM
amsterdamn's Avatar
Originally Posted by noname024
What is this?
Traction control.
Old Apr 11, 2007 | 02:09 PM
DirtyJohn's Avatar
Crap, I thought that pic was yours, it must work different with TCS cars, sorry man.
I can be no help on this one.
Sorry, I'm a horrible person.
Old Apr 11, 2007 | 02:22 PM
noname024's Avatar
Originally Posted by amsterdamn
Traction control.
Ah, thanks. Thought I was missing something there for a sec.
Yup, not my pic.
Old Apr 11, 2007 | 05:51 PM
Yahelou's Avatar
No worry man, U were actually right. I looked at it today and worked perfectly. It tightened the cable exactly what I wanted and it took like practically a minute to do. Its a night and day difference. Thanks a bunch!!
Old Apr 11, 2007 | 05:57 PM
Brads LS1 02Z's Avatar
i had the same TB for a while... my pedal felt stuck as well... but my cable was tight as hell.... did u install the spacer along with it... cant tell by the pic... but personaly ship your stocker off to bo white and let him port it and then put yours in the for sale section and it will get gone within a week... plus i think after bo ported my stocker it made more rwhp then the bbk
good luck either way u deside...
brad
Old Apr 11, 2007 | 05:58 PM
btw... all your acents look sweet haha
Old Apr 11, 2007 | 06:07 PM
5_02ls1's Avatar
the 98s have a smaller t/b cam you ordered the wrong t/b
Old Apr 11, 2007 | 06:31 PM
smaller?
I thought just the spring and shaft were different?
Old Apr 11, 2007 | 09:56 PM
Yahelou's Avatar
Thanks. The problem is I the buddy I bought the tb from didnt have the original spacer with it. Im gonna keep the tb just in case I sell the car, I will take it off and use the original tb. but im just curious, how much would it cost to get the tb ported, and does he do maf's?
Old Apr 12, 2007 | 06:23 AM
not sure about the mafs's but he does the TB's for 60-75... totally worth it... he is a member on the site just look him up... his user name is bo white
Old Apr 12, 2007 | 06:58 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Cam is a different size for sure. it is bigger on 2000+
Old Apr 12, 2007 | 07:48 PM
2000+'s have the bigger cam? thought it was the other way around?
Old Jun 20, 2007 | 12:49 PM
SpdFrk1990's Avatar
How do you adjust the throttle tension on non tcs cars? I just got a summit tb and it has a spacer as well thinking the cable might get too tight.
