Help on pacesetter header install
Old Apr 16, 2007 | 10:31 AM
02camaro_z28's Avatar
Default Help on pacesetter header install
does anybody have any tips or tricks when installing the pacesetter LTs?
Old Apr 16, 2007 | 12:03 PM
Torque_Wrench's Avatar
Get the car up in the air as far as possible. That way you can go in from the bottom.
Old Apr 16, 2007 | 12:48 PM
aaron653's Avatar
make sure that the back passenger plug is in before you put the header in...don't leave a coil pack unplugged when you start it
Old Apr 16, 2007 | 01:22 PM
staringback05's Avatar
+111111...this is probably one of theee most important things
Old Apr 16, 2007 | 01:23 PM
lastcall190's Avatar
Have patience.
Old Apr 17, 2007 | 12:38 PM
00silverGTP's Avatar
I had to grind a tab off the block on the drivers side to get it in. That was the only issue. I used a lift too so that helped.
Old Apr 17, 2007 | 12:41 PM
SimC33's Avatar
I used a lift as well...only issue i had was the drivers side b/c of the steering control arm...i took that off and the rest was easy...
Old Apr 17, 2007 | 12:45 PM
Man you ain;t kiddin'......
Old Apr 17, 2007 | 12:47 PM
You really don't have to grind that tab off. If you can get the car at least 6 feet up in the air...you can manipulate the header enough to go around that.
Old Apr 17, 2007 | 12:51 PM
0utlawTorn's Avatar
When we installed my headers we had to jack the motor up just a tad to get the drivers side in. Passenger side slid right in no problems. Like everyone else said, get the car as high in the air as possible and give yourself plenty of time!
Old Apr 17, 2007 | 01:04 PM
Rokko's Avatar
Tech Addict
remove the coil packs on the passenger side, don't install the back bolt when you re-install the coil packs.
Old Apr 17, 2007 | 01:45 PM
silverbandit0996's Avatar
10mm (i think) gear wrench, a friend, a box of band-aids, and a reminder to plug back in the coolant temp sensor.
Old Apr 17, 2007 | 02:12 PM
FatZ28's Avatar
yeah a 10mm gear wrench is a must. Im guessing your car is an 02 so take the coil packs off and it makes it easier.
