HELP!!! 90/90 change gone awry??
Old Apr 17, 2007 | 08:33 PM
shooter's Avatar
Default HELP!!! 90/90 change gone awry??
I just changed my intake, t/b and the fuel rails, went with a F.A.S.T all the way. And now my car is running really, really chitty??? I didn't have a hard time with anything; it was easier then I thought it was going to be. Now my idle seems to be all over the place and the car is spitting and sputtering. Looks to be running rich, alot of white smoke way more then normal. Then my ARS light won't go out. All I can think of is that I have a loose wire somewhere so I'm going to check everything again in the morning. Any words of wisdom would be greatly appreciated. As always, thank you!!
Old Apr 17, 2007 | 08:52 PM
LS1Formulation's Avatar
Did you change out all the button head bolts in the valley cover? What about reconnecting all your vacuum hoses and the brake booster hose?
Old Apr 17, 2007 | 08:54 PM
brad8266's Avatar
Yep, did you change the valley tray bolts to the button head type that come with the FAST? if you didnt do that than thet bottom of the manifold may be cracked now.
Check for vacuum leaks as they are the primary cause for troubles.
Old Apr 17, 2007 | 09:10 PM
shooter's Avatar
Yup sure did!!
Old Apr 18, 2007 | 09:13 AM
shooter's Avatar
I just check all my plugs and wires still running really bad, alot of white smoke out the *** end??
Old Apr 18, 2007 | 09:15 AM
shooter's Avatar
Reconnected the all the lines and the brake boost hose. I feel like I should take the 90/90 off and start all over, never had my car running like ****.
Old Apr 18, 2007 | 11:49 AM
vettenuts's Avatar
Pull an easy plug to reach and see how bad it looks (wet/black). I know the 90 install throws the tune off, but yours sounds really bad. Did you change injectors too? Also, try spraying some brake cleaner around the intake ports and throttle body to check for leaks. Is there a gap between the throttle body and the intake, there should be.
I am intersted in what you find, I am installing mine next week.
Old Apr 18, 2007 | 12:14 PM
shooter's Avatar
I'll let you know but I have to go to work, breaking out the motorcycle, so I'll have to check it out tonight 1-2am when I get home.
thank-you barry
Oh there is a small gap between the t/b and intake on the under side?
Old Apr 18, 2007 | 01:06 PM
99blancoSS's Avatar
There shouldnt be any gaps between the intake and the tb. If you've got a gap then try taking it off and re-fitting it. Maybe the o-ring got hosed.
Old Apr 18, 2007 | 01:16 PM
vettenuts's Avatar
There should be a gap, but it should be even. If you overtighten the TB, it will bend/break the ears of the manifold. Try spraying this area for a leak.
Old Apr 18, 2007 | 01:26 PM
silent1's Avatar
What manifold gaskets were used? The stock gaskets are a common problem since they don't "fit" or "fill" very well. Fast gaskets are thicker for this reason.
Old Apr 18, 2007 | 03:06 PM
shooter's Avatar
It's was a brand new intake and new fast o-ring everything fit very well and seemed tight.
Old Apr 18, 2007 | 03:07 PM
shooter's Avatar
The gap doesn't seem to be even I didn't over tighten it but i'll be checking it again!!!
Old Apr 18, 2007 | 03:15 PM
bayer-z28's Avatar
I've acutally accidnetally set a For Taurus on fire doing that. Just reassembled the engine, was checking for intake leaks and WOOOF! Soemhtign on the ignition must have sparked it... It didn't doo much dammage case there was a fire extinguisher about 10 feet from me.
That trick does work, tho. If the idle changes, then you found the intake leak.
Anywya.. Not too familiar w/ the 90/90's but do they still retain the MAP sensor in the back? If it's running excesivley rich, you may have an intake port leaking and the 02's are picking up on the extra air in the system and compensating w/ more fuel, thru the computer.
just my $0.02.......
Old Apr 18, 2007 | 03:24 PM
shooter's Avatar
I quess i'm going to pull it back off and check everything over again!!!!
Old Apr 18, 2007 | 03:32 PM
brad8266's Avatar
If the MAP senor was unpluuged you would have a lean condition not a rich condition and your idle would be very high.
Old Apr 18, 2007 | 03:37 PM
shooter's Avatar
May maf is plug in, I checked to make sure everything is plugged in.
Old Apr 18, 2007 | 03:42 PM
99blancoSS's Avatar
no gaps on my 90/nw90
Old Apr 18, 2007 | 03:46 PM
shooter's Avatar
Now I've heard that F.A.S.T T/B have had problem in the pass and have had to be sent back for rework could this be the problem???
Old Apr 18, 2007 | 03:47 PM
brad8266's Avatar
Not MAF, MAP. The MAP is on the back on the manifold.
