Where does the water go?
<img src="http://communities.msn.com/_Secure/0MwD**74QjJmAQyusDSi8K3vklQt9LDzBU8smEoxqMQAy2JQrk zVjrIFyKcq4WMbQOxeIpWvBsAABLQyYhmVUWg/Pict0010.JPG" alt="" />
<img src="http://communities.msn.com/_Secure/0MgDPGTQRCapxO5kRmPOfXI9TuLGy8XtDyYnMgoxcTy69nRmOi oXhuLX*ZVT0AviPpzRo93HlF4PMWAheLMDSOw/image13.jpg" alt="" />
If you want to see more photos go here.
If you have any questions let me know. I will not have to car off the jack stands for another two weeks so I cant tell you how it works until then. I have about $6 bucks into the cost of this. I bent all of it by hand, but I also use to do metal work a long time ago. I'm not sure if rain will work its way up but most likley it would if I was driving on the freeway fast the velocity alone would take it up. I might put a screen on it when i drive to the track to keep bugs out.
<small>[ March 29, 2002, 07:53 AM: Message edited by: 2000 Camaro SS ]</small>
As for the other setup above you could do that and put some kind of demister pad to knock out the water. It would more than likely have a higher velocity than the SS style and will be a lot cooler air. This is just my opinion. I would like to here any more thoughts.
It says it will work with cars.
