Wanting more low end and throttle response
I don't think that the Cat's are going to do it for you.
BTW do you have a aftermarket cam? or heads?
If you don't have heads adding some compression ratio could help you.
Bret
You want more low end? Simple, get more cubes! These cars should come from the factory with a 382ci haha.
Tony
is there still a single 3" catback behind it? Then that should reduce it enough.
Tony
TTT <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<strong>You could always change the T/B cam that's attached to the throttle cable. I know in the 60's Pontiac had a faster cam than Chevy had. I don't know if this is still the case, but it you have chevy you could always try. Bret</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Interesting... Anyone ever tried this?
If you're not already doing something like this, one thing that will give you better throttle response is running Lterms that are slightly positive - up to maybe 10% as measured with AutoTap. This will reduce your calculated load factor and therefore crank in a bit more timing at part throttle. As long as you don't get any knock it should (and this is the best way I can describe it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ) make the car feel lighter and a bit more responsive. I've done this with a MAFT/MAF ends, etc. LS1Edit may be even better for this type of work, but unfortunately I don't have any experience with it yet <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Anyway, just a thought.
As delivered, the SLP Y that comes with the headers is dual 3" into a single 3"... I recently bought a Flowmaster Y that's dual 3" into a single 4" to mate with the Mufflex that'll go in when I go heads/cam.
What I am thinking is this- that with a 3" Y the car feels sluggish down low, but that is only because it pulls so well up high. Ever ridden a Yamaha R6?? Same thing... people say that they have no low end to them- simply not true. What IS true, though, is that when compared to the top end of the power band, the lower end feels mushy.
Or maybe I'm babbling; you decide... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
