If you installed an LS6 intake, please read! You may have torque problems too!
Moderator
Long story short .... I just installed my 30# SVO injectors and to make it easy reinstalling the fuel rail I also removed the drivers side metal rear fuel rail stop tab. Upon reinstalltion and preparing to torque the two intake manifold bolts holding the metal tab down I decided to check the other bolts' torque starting at 44 in./lbs. as specified in the Service Manual. Was I ever shocked.....
Starting at #1 (middle bolt) with the torque wrench, it went a full 1/3 turn before it clicked at only 44 in./lbs <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> This was basically the same situation for all of the bolts! When I stepped it up to the final 89 in./lbs., the bolts almost went a full 2/3 more additional turn <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> for a total of ~1 full turn!!!
I was in absolute disbelief! Had I not been so picky and triple checked the torque values when I installed the intake manifold 4 months ago I would never believe that it was torqued properly or even retorqued after I installed it.
When I orginally installed the manifold I used anti-seize on the threads and they were perfectly clean. I reused my old intake gaskets when I installed the intake since they appeared to be perfect (my motor only had ~ 11K). How is this possible after I did a hot retorque the first time???????
Bottom line, you may want to check your bolts to!
Re: If you installed an LS6 intake, please read! You may have torque problems too!
hahaha Ok, now, you have my attention. I didn't use locktite last time. I remembered right after I got them all tightened up. DOH!
So I am giving it a few weeks and going to check them. I will check them tommorrow.
That's a good heads up.
Eric
Eric
LSxGuy widda 9sec Mustang
You should have used the brand new gaskets I sold you! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
All "captured o-ring" type gaskets seem to shrink or something over time, mark your bolts and see if they are actually loosening...check back in another 4 months <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
What gaskets are needed for the ls6 intake? I got a used one sitting here to be put on soon and I wasn't aware that I needed gaskets.
They are talking about the 8 individual gaskets on the bottom side of the intake for the intake ports where they meet the head.
I am going to check my bolts today. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Eric
Eric
Moderator
-Joseph-, that was my original plan (to use the new gaskets), however, I am putting a set of fully ported heads on within a month or so and thought that I could squeak by with the originals until then (since "everybody was doing it this way") but I guess not!
So are we supposed to use loctite blue???
I installed my manifold the other day, I've checked the bolts twice now and they are still tight. I didn't use loctite or anything, because nobody told me to.
I checked my bolts and they had lost torque. So I retightened them. That is weird...
Yes, the manual says to use locktite. It is blue in a red tube. The kind for vibrations and that can be taken loose with hand tools. The weak locktite.
ERic
ERic
Guys,
The intake manifold material (nylon6-6) can cold flow. This means you cannot rely on it to hold bolt torque. You really need locktite or something similar...
