oil dipstick please help
Old Apr 25, 2007 | 07:16 PM
derekws66's Avatar
Red face oil dipstick please help
im doing my headers and im having a bitch of a time getting out the dipstick it should just pull out cause its pressed in right? tips please would be awsome
Old Apr 25, 2007 | 07:27 PM
FireSilverLullaby's Avatar
Well mine came right ourt. but make sure you unbolt the one bolt holding it in. Then just pull the hell out of it. if its still stuck, find where it connects to the oil pan and get a screw driver and try to pry it out. good luck
Old Apr 25, 2007 | 07:34 PM
2001NBMZ28's Avatar
Yeah there's a 15MM? bolt holding the tube on - the hardest part is getting it back in.
Old Apr 25, 2007 | 07:40 PM
Camaro94SS's Avatar
lolol....you gotta go from under the car, unbolt the tiny tiny bolt....then it should pull right out....putting it back in you have to have someone hold the dipstick and communicate to line up the hole fromt he top and put the bolt back in.....had to take it off for my plugs and headers....terrible
Old Apr 25, 2007 | 07:45 PM
yeah when you start your car with open headers this will all be worth it.
Old Apr 25, 2007 | 09:19 PM
theblur98ss's Avatar
Quick tip when putting the dipstick back in. Put the tube in first and then put the dipstick itself in. I did headers one time and shoved the whole thing in there at once. Something with the stick didn't line up and my crank ate the end of the dipstick. Scared the crap out of me for a little bit until I realized what happened.
Old Apr 26, 2007 | 06:24 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I used took the stick out, unbolted it from the header and it slid out. As for putting it back in, I got it close, then from under the car slid it into the block.
Old Apr 26, 2007 | 06:41 PM
derekws66's Avatar
thanx guys it I cant wait till im done
