!Free Mods
Old Nov 16, 2001 | 07:20 AM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: !Free Mods
There are a plethora of free mods on my web page.
But it seems you have used quite a few of them...
I did not see where you ported your Throttle body or indexed your plugs, or installed a clamp to stop the motor from torqing over, or boxed the LCA's, or raised the Coils off the valve covers, shoot... looking over your list, you have missed quite a few. (sorry, i have been awake all night and i want to crash, but there's LOTS more you DONT have)
Better get busy! <img src="images/icons/smile.gif" border="0">
Old Nov 16, 2001 | 08:17 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Raugh, looking at your page gave me an idea. When you epoxy the TB, what size holes do you have to drill. I'm assuming if you don't drill the holes you will have no idle?
Anybody feel free to step in here.
Gerald
Old Nov 16, 2001 | 08:35 AM
blackhawk2000's Avatar
[quote]Originally posted by Raughammer:
<strong>or raised the Coils off the valve covers,</strong><hr></blockquote>
You lost me on this one. Why?
Old Nov 16, 2001 | 08:46 AM
Patman's Avatar
Raising the coils off the valve covers would keep them cooler, therefore allowing a stronger spark. Sort of like how the C5 guys will remove the cover from the engine to keep the coils from heating up, I believe some of them found a one tenth gain from this change.
Old Nov 16, 2001 | 08:58 AM
00 Super Sport's Avatar
So how do you keep from throw a code with the air pump gone?
Old Nov 16, 2001 | 09:02 AM
Crazyquik's Avatar
custom tuning, or stare at the SES light like I am...
J.
Old Nov 21, 2001 | 01:33 PM
CHRISPY's Avatar
hee hee
you can use a piece of black elec. tape to cover the SES light <img src="images/icons/smile.gif" border="0"> I am running without EGR and AIR pump (Though they are still in the car, just not connected) If you have scanmaster or ATAP you dont have to worry about it.
Cheers,
Chris
Old Nov 22, 2001 | 12:13 AM
DV8's Avatar
DV8
<strong>indexed your plugs, or installed a clamp to stop the motor from torqing over</strong><hr></blockquote>
Is indexing the plugs adjusting the gap size according to your engine performance (dyno information)? I've never heard of it.
What kind of clamp and where to install it to keep the motor from torquing over?
<img src="images/icons/confused.gif" border="0">
[ November 21, 2001: Message edited by: DV-8 ]</p>
Old Nov 22, 2001 | 08:01 PM
MUSTANGEATER's Avatar
Should I do the FRA mod on a WS6?
Old Nov 23, 2001 | 03:18 AM
99taws6's Avatar
[quote]Originally posted by Chris ARE 360:
<strong>hee hee
Cheers,
Chris</strong><hr></blockquote>
So you are telling me that ATAP or scanmaster can clear the codes permanently? I would remove mine if I know this to be true.....
Old Nov 23, 2001 | 07:13 PM
andy98Z's Avatar
I combined two Free Mods to make Them more efficiant. I put Tubes mounted under my front facia directed up and through my Free Ram Air, This has to help out up in the 100's. I have 2 black circles on my filter. Now I have 4 Tubes <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ November 23, 2001: Message edited by: andy98Z ]</p>
Old Nov 24, 2001 | 09:04 AM
  #32
Raughammer's Avatar
D(irecto)r Pepper
[quote]Originally posted by gwj:
<strong>Raugh, looking at your page gave me an idea. When you epoxy the TB, what size holes do you have to drill. I'm assuming if you don't drill the holes you will have no idle?
Gerald</strong><hr></blockquote>
Your right... you HAVE to have an hole. What siaze? I just kept increasing it till it was what I wanted. Sorry, I dont know the size... but it is pretty small.
Raughammer <img src="images/icons/cool.gif" border="0">
Old Nov 24, 2001 | 09:07 AM
  #33
Raughammer's Avatar
D(irecto)r Pepper
[QUOTE]Originally posted by DV-8:
[QB]
... no it is installing your plugs so that the open face of the plug is facing the incoming charge. (that is how i do it)
... it is an turnbucle.. it is mounted on the drivers side of the motor and the frame to keep the motor from torqueing over.
Good luck.
Raugh
Old Nov 25, 2001 | 10:04 AM
  #34
TA/30th 1002's Avatar
Ref Thermostat mod:
When I modded my stat a few months back, I first thought of installing a spacer exactly as illustrated by the pics posted by RyanJackson. I felt installing a spacer as such would create greater stress on the housing ears and also have an effect on the valves closed seat pressure.
I elected to simply change the spring with one I had in a "I may need that some day" collection. My regulators open/close temps are now pretty much 10 degF lower than stock.
Just thought I throw another option out.
... 1002
[ November 25, 2001: Message edited by: TA/30th 1002 ]</p>
Old Apr 16, 2002 | 01:41 PM
  #35
RacerX's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WILWAXU:
<strong>Remove your air pump, block off the air tubes. It's under the drivers headlight.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Air Pump MOD I've seen on several dragsters running in super comp status had it set up to suck on the crankcase to get rid of all crankcase pressure cause from blow by. They seem to gain power from it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 16, 2002 | 03:44 PM
  #36
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RacerX:
<strong>Air Pump MOD I've seen on several dragsters running in super comp status had it set up to suck on the crankcase to get rid of all crankcase pressure cause from blow by. They seem to gain power from it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That would be a crankcase evac pump.. BIG difference.
Old Apr 16, 2002 | 03:58 PM
  #37
2000 Camaro SS's Avatar
Yah your missing my ram air
<img src="http://communities.msn.com/_Secure/0MwAAAMAQ4JmAQyusDSi8Kw37Y72wm0gElas30XKoxYBaB4NXL K8lsFpnGnxctJ3l!SN0AMoGyMdteDw8K1Cxnw/Pict0012.JPG" alt="" />
It's not like the rest of them this one is fully functional. More photos on my home page.
<small>[ April 16, 2002, 04:03 PM: Message edited by: 2000 Camaro SS ]</small>
Old Apr 17, 2002 | 01:21 AM
  #38
Ozzydragracer's Avatar
Regarding the air pump, you CAN use it as a crankcase evacuation pump. Before the aftermarket made available evacuation pumps, drag race cars from dragsters to Pro Stock cars used OEM air pumps, modified to PULL air from somewhere (this case it was oil pan) and out to atmosphere.
I have done this on a friends 8 second small block 350 sedan about three years ago. Picked up MPH immediatley, BUT you have to seal the engine VERY good, no breathers, etc. Everything MUST be sealed. If your doing it, put a vacuum gauge where the driver can see it going mid course and through the lights. Should pull a vacuum of at least 2 through the lights! Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 17, 2002 | 04:00 AM
  #39
Raughammer's Avatar
D(irecto)r Pepper
Specificaly, which OEM air pump are you refering to?
Campbell
Old Apr 17, 2002 | 06:05 AM
  #40
We used a GM Holden (Aussie) air pump, and it worked terrific. Took some mating to do with the mount. I believe it is still on the car to date.
Don't have a part number, it may be the same as some of the USA made pumps. Hope this helps! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
