which lid has better fit
Old Apr 23, 2002 | 08:59 PM
ChrisWS9's Avatar
Default which lid has better fit
MTI or Whisper
Old Apr 23, 2002 | 09:07 PM
Z-Rated's Avatar
Default Re: which lid has better fit
I have a MTI lid and i dont have any problems
Drew
Old Apr 23, 2002 | 09:37 PM
Onyx LS1's Avatar
go with the MTI...
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000649
Old Apr 24, 2002 | 07:02 AM
WILWAXU's Avatar
Umm.. no offense.. but I see people there that have rubbing problems with all the lids.
Most of the times I've seen fitment problems.. it's been do to a couple things. 1) not installed properly (more common than you think). 2) A raised lower airbox. 3) Fernco Mod.
Basically, your going to hear 10 different opinions on each of these lids, everyone will come up with 10 reason why "they're" lid is better. In all truthfullness.. they all are pretty close.. go with the one you like best.
I personnally don't think you can go wrong with ethier of the lids you mentioned.
<small>[ April 24, 2002, 07:10 AM: Message edited by: WILWAXU ]</small>
Old Apr 24, 2002 | 05:26 PM
ChrisWS9's Avatar
i had a whisper once i know it fits good but i like the mti clear i do have a ws6 box but i have the hood now also
Old Apr 24, 2002 | 05:38 PM
cobrakillerta's Avatar
There pretty much ALL the same...
Go with whichever you like better...or has a better price <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ April 24, 2002, 05:39 PM: Message edited by: cobrakillerta ]</small>
Old Apr 24, 2002 | 08:46 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I tried two Whispers, a Direct Flo, and an MTI lid on my T/A, and the MTI fit the best, by far, for me. They all rubbed the top of my hood, FWIW, with the WS-6 lower airbox and Suncoast Raptor hood. Both of my Whispers fell apart, and the Direct Flo didn't fit too well. The MTI lid held up great and fit excellent. I'm running an MTI lid on my SS w/ no rubbing problems.
__________________
Old Apr 27, 2002 | 10:45 PM
BillWS6Formula's Avatar
I've had Whisper, and now the MTI. Fit is good on both, but the Whisper is pretty fragile - breaks apart in the neck area. The MTI seems much sturdier. Plus you can't beat the looks... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.netsnapshot.com/users/8982/images/PMnxKsCoBQIAACK5NNo_8982_6.jpg" alt="" />
Old Apr 29, 2002 | 09:49 PM
Dave Jones's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cobrakillerta:
<strong>There pretty much ALL the same...
Go with whichever you like better...or has a better price <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">One lid I bought was very badly formed. I won't say what kind it was, because I'm not completely sure. (It's at home and I'm at the office.) The reason I got the brand I did was because it had a fitting for the AIR hose.
Rather than sending the lid back as I probably should have, I spent a lot of time grinding on it with a Drimmel tool and a sand paper block, and filling areas with plastic epoxy. I finally got it flat enough. But after I installed it, I realized that the AIR hose feature was very badly designed. The hose pulled sideways and up in its rubber grommet and tapped against the hood.
I also bought an SLP lid. The seal was much flatter than the other one, but I still filled some low spots and did a little flattening on it. I had to use a separate little filter for the AIR thing, but it turned out that was no biggy. I figured out a way to attach it so it doesn't rub on anything. The SLP lid is the one I'm using. It rubs on the hood a little at one of the front corners, but I have the air box raised with three washers.
