How to swap alternator pulley?
Old May 9, 2007 | 12:11 PM
Michael02hawk's Avatar
Default How to swap alternator pulley?
I assume it straight forward enough to simply unbolt the nut, remove the old pulley, install the new one, then re-bolt the nut?
Also, what is the torque spec for that nut?
Old May 9, 2007 | 01:33 PM
BigD 275's Avatar
Yeah, straightforward. Just unbolt. It has been a few years since I did mine so I don't remember the torque specs.
Also, I think I used a big screwdriver to hold the alt. pulley from turning when you initial break the bolt loose.
Don't worry. Very easy to change.
Old May 9, 2007 | 02:34 PM
Z's Z-28's Avatar
i do pulley swaps about every weekend at work, we just take an impact, take the nut off and impact the bitch back on, done in less than a minute if ur good at it
Old May 9, 2007 | 07:09 PM
How the heck am I suppose to break the nut loose??
The stock pulley wants to spin with the wrench/nut - I dont see a place on the pulley to get a grip.
Or am I suppose to wedge a screwdriver inside the alt on one of the fins inside there?
any suggestions are great, Id like to get this thing off and swapped tonight if possible.
Thanks
Old May 9, 2007 | 07:15 PM
GR33N GoblinM6's Avatar
impact is the only thing that will do it right.. and fast... i took my alt down to a local automotive shop.. you know the kind that do everything...
asked one of the techs to zip off the nut off.. took 2 seconds.. and it was free..
Old May 9, 2007 | 07:18 PM
Oh, so I have to remove the alternator and bring it to a shop?
Damn, thats no fun!
But thanks for the info.
Old May 9, 2007 | 07:28 PM
yeah.. because if you try and remove it another way.. you risk damage to the alt.. its not hard to pull the alt.. 4 bolts and 2 wires..
Old May 9, 2007 | 08:29 PM
sunsetta's Avatar
Box wrench on the nut with a torx bit socket in the end of the shaft to keep it from turning.
