Is this the IAT sensor?? or what??
Old May 11, 2007 | 10:23 AM
Stang's Bane's Avatar
Default Is this the IAT sensor?? or what??
The plug on the back driver side of the lid?? Or what is it??
[IMG][/IMG]
While I am at it, anyone know the size of the bolts that hold the upper radiator support to the frame??
Old May 11, 2007 | 10:42 AM
mcamarols1's Avatar
yeah thats it, and i think the bolts are 10mm
venom346's Avatar
You are correct that is the IaT sensor.. not sure of the length, but the bolts you are talking about are tightened / loosemed with a 10mm wrench
Old May 11, 2007 | 12:50 PM
TheBlurLS1's Avatar
That's what she said...
I believe the bolts have 6mm threads, not sure of the pitch.
Old May 11, 2007 | 01:59 PM
Thank you, I was wondering about the threads
Old Mar 31, 2008 | 12:31 PM
willfong's Avatar
Anyone can give some advice on how to remove this IAT sensor from the air intake without damaging the sensor and/or the air intake? It seems to be stubornly attached with a rubber grommet or something?
Old Mar 31, 2008 | 12:35 PM
M-Ten's Avatar
that's what that is?? is that the sensor that runs the temp gauge on the dash?
Old Mar 31, 2008 | 12:54 PM
thunderstruck's Avatar
pull and roll it in a circular motion at the same time
Old Mar 31, 2008 | 12:55 PM
no the iat lets the computer know incoming air temp to help adjust fuel & spark
the dash temp gauge is from the sensor in the side of the head near the #1 cyl exh port
Old Mar 31, 2008 | 12:56 PM
M-Ten's Avatar
yeah taht's what i thought.. reason i'm asking is because my temp guage heats up and reads, but the gauge won't go above like 110.. so I replaced the sensor on the driver side, but it didn't fix it.
Old Mar 31, 2008 | 03:16 PM
willfong's Avatar
Thanks for the motions. Will I need lotion too?
Seriously would you think alil WD40 might help things out while Im pulling and rolling the sensor out?
Old Mar 31, 2008 | 03:23 PM
BlackScreaminMachine's Avatar
Internet Mechanic
That should be the sensor as far as the PCM reads is off of the driver side's cyl head, w/ exception of 1998, pretty much its a dummy guage. It works but its not as accurate.
As for the post it self.
I want to say yes.
+1 Post count, Zing!!
