What sensor did I break off? (pic)
Old May 11, 2007 | 02:27 PM
fastGBcamaro's Avatar
Default What sensor did I break off? (pic)
This is the sensor on that sticks straight up and is located on the back of the block and would be behind the intake manifold. What sensor is it and does anyone have a guess how much a new one costs?
Old May 11, 2007 | 02:33 PM
floman's Avatar
Oil pressure sensor. Cost? I'm not really sure, maybe $40.00 or so?
Old May 11, 2007 | 02:34 PM
2001NBMZ28's Avatar
That would be the oil pressure sensor. PN is 12562267 (for 99-02) and lists at about $62 at the dealer now, cheaper from a sponsor or local parts store.
Old May 11, 2007 | 02:49 PM
Default Thanks
Thanks guys Ill check out SDPC and see what they charge.
Old May 11, 2007 | 02:56 PM
TheBlurLS1's Avatar
That's what she said...
If you install it while the motor's still out, you'll be able to use a crescent wrench instead of buying the special socket. BE CAREFUL on re-install.
Old May 11, 2007 | 06:08 PM
Cerberus's Avatar
I ordered my oil pressure switch from Autozone. Cost about $30 and arrived the next day.
Old May 11, 2007 | 06:13 PM
davered00ss's Avatar
Moderator
Old May 11, 2007 | 10:37 PM
venom346's Avatar
The oil pressure sensor socket is pretty cheap anyway, $4.00
Old May 12, 2007 | 12:43 PM
408 z28's Avatar
$35 from GM
Old May 12, 2007 | 12:47 PM
Zentenk's Avatar
Where can I get the special socket, I got one big enough to remove the broken nut but I couldn't get one long enough to slide over the new sensor the screw it in.
Old May 12, 2007 | 03:49 PM
TheBlurLS1's Avatar
Any autoparts store should have one. Bring the sending unit up there and make sure you have the right one.
Old May 14, 2007 | 09:50 AM
AutomagicLS1's Avatar
Everyone should change these when they have the intake off. I learned the hard way and thought I had oil pressure problems inside. All you have to do is bump the sensor and it quits working it seems like
