K&N filter question.
Old May 28, 2007 | 03:06 PM
TransAm_00's Avatar
Default K&N filter question.
After cleaning the filter, do you have to spray the oil stuff on the filter? Wouldn't the filter alone work just fine? Does anyone do this? Also is there anything else to use to clean the filter other than what comes in the filter re-charge kit.
Old May 28, 2007 | 03:57 PM
TransAm_00's Avatar
Anyone?
Old May 28, 2007 | 04:27 PM
TransAm_00's Avatar
Well, I'm using Purple Power to clean it right now. So hopefully when I hose it off it will be clean. I just need to know about the oil.
Old May 28, 2007 | 04:28 PM
JohnnyC's Avatar
The oil is required, and they sell the cleaner and oil at most autoparts stores.
Old May 28, 2007 | 04:47 PM
2001NBMZ28's Avatar
Mine gets dirty quick cause of the FTRA - been using the same filter since early '01, just cleaning it with K&N's filter recharge kit - still have enough left in the kit for another few years. I always let it dry thoroughly and then LIGHTLY oil the filter.
Old May 28, 2007 | 04:53 PM
TransAm_00's Avatar
I have always use the oil, but I was wondering if I could use a clean filter without using the oil.
Old May 28, 2007 | 05:23 PM
davered00ss's Avatar
Moderator
You need the oil. it is the oil that traps the dirt.
Old May 28, 2007 | 06:12 PM
WS6WRX's Avatar
The oil swells the cotton fibers and helps trap the dust particles, without the oil much larger particles would be able to pass through the mesh. In a pinch you could use some other type of aerosol oil until you can get the right stuff.
Old May 28, 2007 | 06:16 PM
Big Bird WS6's Avatar
don't use k and n. it sucks. there is no horse power increase using it. and they leak on the short sides. paper is just fine
Old May 28, 2007 | 10:09 PM
2002BlackSS's Avatar
I've got a Holley, but I've never installed it. I got it used, but supplied with a cleaning kit/oil, and I'll agree - you must LIGHTLY oil it. I put way too much oil on mine, so I've been trying to get it to dry to the point that I can trust it. If I can't, I may just reclean it, and start over.
