Porting your own TB
Old Jun 3, 2007 | 09:46 AM
9ball's Avatar
Default Porting your own TB
What would it require to do this? Just some different grit sandpapers and polishing compound?
Thanks folks
Old Jun 3, 2007 | 09:50 AM
04goatman's Avatar
I don't know but u can send in ur throttle body to era performance to get it ported & polished for $80, good deal but will TAKE A WEEK.
Old Jun 3, 2007 | 09:52 AM
matthewjosh's Avatar
I used a dremel tool with a cutting bit, a drill with a grinding stone, and then used a dremel with a polishing pads and sanding pads.
Old Jun 3, 2007 | 11:32 AM
RZRSEDGE's Avatar
Yeah, I just went with a dremel with cutting bit, sanding rolls, the polished it out with some micro paper that I got from work. It's like glass!
Old Jun 3, 2007 | 11:35 AM
Tainted's Avatar
just let tim send you a ported TB for $40 and send him your stock one that way you have no down time and you know its done right
Old Jun 3, 2007 | 12:00 PM
Red99TA's Avatar
All you need is a sanding drum with a couple very course sandpaper rolls and then a couple fine rolls. If you want to polish it then you'll need some much higher grit sandpaper which I do by hand (all the way up to about 1500 grit) then polishing with a buffing wheel and some polishing compound. I don't think there's any performance advantage from polishing...more of an appearance mod.
Old Jun 3, 2007 | 02:37 PM
9ball's Avatar
Wonder if porting is even worth it ... I would think at most it would give 5HP ... maybe. Think I'll just get some sandpaper and do it by hand (don't have a sanding tool/dremel). Might take over an hour, but I'll have a lot of time on my hands tomorrow, lol.
Old Jun 3, 2007 | 02:57 PM
dyls1's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/724149-ported-tb-sale-40-shipped.html
Went through this guy and was extremely happy with his work and the quick turnaround
Old Jun 3, 2007 | 04:49 PM
9ball's Avatar
Originally Posted by dyls1
https://ls1tech.com/forums/showthread.php?t=724149
Yea, that's an awesome offer ... but a few bucks for some serious sandpaper and getting similar results may be the way to go for me. Can't see even the best porting job getting much more than a home job. Who knows tho, I'll take my TB later today and see ... that 90* opening may help quite a bit, dunno how far the stock TB opens up
Old Jun 3, 2007 | 05:08 PM
95 Z28's Avatar
I ported mine and a few of my buddies. I usually use sanding rolls, and it takes a while with just using them. I've got a spare one laying here and might try some sort of metal bit. After using the sanding rolls, I'll take some fine grit sandpaper and smooth it out, not really polish it to a mirror finish, just to clean it up and make it a little smoother.
Old Jun 3, 2007 | 05:31 PM
Bo White's Avatar
I have posted up ways of porting your own so you can look around for them and other threads about how to do it. I can port em, Tim can port em, New Era can port em.....and the list goes on....
BTW, a properly ported TB will have the gains in the link in my sig
Red99TA's Avatar
9ball - You will NOT be able to do it by hand unless you plan on using something like a 50 grit and spending about 10 hours but your fingers will be raw long before then. As for the bump stop mod (the 90* opening) it's a good idea and easy to do. You have to be careful with that. If you go even 1/4 of a degree past 90 then you'll trip a SES light. Best way is to read the TPS voltage and sand it down a little bit at a time to ensure you don't go past the 90*. I don't remember the exact voltage to stay under (volts rise as the throttle opens) but do a search and you'll find it.
Old Jun 3, 2007 | 07:07 PM
cls1gto's Avatar
I say let the guys who know how to port them do the work, it's worth the peace mind knowing that it's done properly. also not taking the risk orf ruining your tb & have to buy another one anyway. I used Tim from performace throttle body & he did a great job, all did was bolt it on & have had no eng. light issues & the car has better throttle response. I highly recomend him.
Old Jun 4, 2007 | 09:17 AM
Grimes's Avatar
It is definitely worth it. Bo posted up real dyno results a while ago, and I know my butt dyno felt results as well!
Old Jun 4, 2007 | 03:53 PM
Smokin87TA's Avatar
Restricted User
Yea its definitely a very worthwile mod that has price per hp gains around $8 per rwhp. those gains are close to nitrous for those numbers. I know we have been talking in pm's and you say you have an ls2 tb. Its impossible to do by hand, i know me and Bo can both attest that even with a very aggressive metal bit, then aggressive sanding rolls on a air die grinder these tb's take us over a couple of hours. The ls2 tb is about 2 times as hard to port compared to an ls1 as well. It wont hurt to try but isnt possible, If your going to do it yourself at least pick up a dremel or die grinder, It will cost more then sending your tb out to one of us, but then you have another tool to use for other jobs. Tim
