Radical Radiator Relocation?
Old Apr 12, 2009 | 03:07 AM
  #41
BAMF's Avatar
How are you going to check the level in the rad? I just don't see the point to all that, unless your making room for turbos all you have done is make the front of your car weak.
Old Apr 22, 2009 | 10:48 PM
  #42
JasonWW's Avatar
Some update pics.
Old Apr 22, 2009 | 11:00 PM
  #43
JasonWW's Avatar
A few more.
Next:
Lower rad mount
Bumper cover supports
Hoses
Expansion tank
Hood latches (as in 2)
Hide all underhood wiring
Add beefy lower front bar for lifting and towing
More bracing
etc...
Old Apr 22, 2009 | 11:02 PM
  #44
Ice78Transam's Avatar
Your the ****. And sweet Hobart! Glad someone actually practices what they preach. Re-subscribed.
Old Apr 26, 2009 | 11:55 PM
  #45
1999 SS's Avatar
im impressed.
you've had a few guys say there would be no gain but if nothing else i think the self satisfaction alone would be all the gain your looking for.
Old Apr 27, 2009 | 01:28 AM
  #46
letsrunem's Avatar
Cool!
Old Apr 27, 2009 | 02:23 AM
  #47
JasonWW's Avatar
Next:
Make lower rad mount - Done
Make bumper cover supports
Hoses - Done
Add expansion tank - Got it, not installed yet
Hood latches (as in 2) - Got it, not installed yet
Hide all underhood wiring - In process
Add more bracing
etc...
Move battery to rear - In process
Hide TCS motor - In process
Filled in holes on shocktowers - Done
Relocated vacuum tank near PCM - Done
Old Apr 27, 2009 | 03:06 AM
  #48
35th SS's Avatar
I hope you dont get involve in a head on crash.you just have way too much free time to be doing this.you are hardcore mang chopping the front end of a street car like that.
Old Apr 27, 2009 | 03:16 AM
  #49
JasonWW's Avatar
Originally Posted by 35th SS
I hope you dont get involved in a head on crash.
Same to you.
You just have way too much free time to be doing this.
I gave up TV.
You are hardcore mang chopping the front end of a street car like that.
It's fun!
Old Apr 27, 2009 | 11:22 AM
  #50
slammed1500's Avatar
looks good man
nice job
Old Apr 27, 2009 | 04:18 PM
  #51
JasonWW's Avatar
Originally Posted by slammed1500
looks good man
nice job
Thanks.
I guess the forum thinks were both officially "crazy" now.
Old Apr 27, 2009 | 04:28 PM
  #52
01ssreda4's Avatar
great work so far, i completely understand the project bc i think the front of f bodies have a lot of wasted space that could be utilized better. but, i have to ask, how do you ever get to drive your car if its always torn apart??
Old Apr 27, 2009 | 04:44 PM
  #53
JasonWW's Avatar
Well, when I daily drove it I was very limited as far as the mods I could do. Everything I did had about a 24-48 hour time limit to get finished. I drove it 5 years straight and now that I have a dependable 2nd car, I'm taking the time to do the stuff I always wanted to do.
I also threw a rod through the block a while back so it sat for a while. I wish I had the time and money back then to do a bunch of mods, but all I could do was just some cutting. I got the engine replaced, but it still sat there cut up. Then 2 weeks ago I stopped working on my big project car to focus on getting the black one back on the road.
I think I'm rambling now. I hope that answers your question.
One more thing. I should have the front end done very soon and be back on the road with it. I'll be installing an airbag suspension, but that will take only a day. The next big tear down will be for the IRS and tank relocation. As my skills improve the work goes along faster.
Old Apr 27, 2009 | 05:22 PM
  #54
Texnmissouri69's Avatar
Keep it up Jason. Great work. Looks like a HELL of a lot of work, thinking and planning. It's different and unique for sure. I admire you about that. I love to fabricate and be different as well. Please keep up the thread with pics and progress. Looking good so far.
Old Apr 27, 2009 | 06:55 PM
  #55
01ssreda4's Avatar
i think the airflow should be sufficient with the route you have chosen, but are you planning on channeling the air directly into the front of the radiator or after it leaves the radiator?? i ask that bc most all factory systems are somewhat channeled before and of course to a water pump driven fan and such after the radiator. i can only assume this is to maintain air velocity and speed with air direction sort of being a byproduct.
Old Apr 27, 2009 | 07:09 PM
  #56
LS6427's Avatar
Originally Posted by JasonWW
[B][SIZE="3"]
Here are some progress pics on the black one. The rad is just mocked up in approximately the new location.
I'm all for new cool changes. I have one of my own for the back of the cooling fans.
But I don't think you're going to get much air slamming into the radiator in that position. The front bumper pushes air away from its frontal areas. I don't think that hole is going to matter.
Old Apr 27, 2009 | 07:12 PM
  #57
LS6427's Avatar
Some update pics.
DAMN, kickass that you're actually doing it.
Old Apr 27, 2009 | 09:55 PM
  #58
JasonWW's Avatar
Thanks, most folks just scratch there heads and wonder why I do what I do.
Sorry, I really don't know what your saying.
All air will be channelled into the A/C condensor/radiator through the 3 holes in the nose. I actually have more air inlet size than stock so cooling won't be a problem.
Old Apr 27, 2009 | 10:02 PM
  #59
JasonWW's Avatar
First of all, the center hole is larger that that pic. Look at the newer pics and you'll see. It's not finished, yet. There will be a flat sheet under the rad and triangle side pieces that will form a big scoop so all air entering the nose will be forced through the condensor/radiator. The fans will only be needed when parked.
The exhaust air will circulate around the engine much more than the stock setup which pushes it down right away. I may also swap to one of my steel hoods and fab up an air extractor in it to reduce air flow under the car. I could also make a scoop under the hood to help vent it. Exact air flow routing under the hood can be looked at and altered later. I'm not worried about it right now.
Old Apr 27, 2009 | 10:27 PM
  #60
JasonWW's Avatar
So I shaved off all remains of the upper crossmember. There's a lot of misc crap there. Both sides are now smooth, but I left the hood posts for now.
I made a simple steel support for the fender to nose bracket.
Figuring out the lower radiator support was the most difficult because you can't weld to the radiator at all. Eventually I came up with this.
The square nub sticking up is to lock the radiator down. I'll come up with something simple later.
This setup has one small drawback, you have to slide the A/C condensor off before you can swing the radiator up and out. Here is the condensor mounted.
From the side.
The air scoop will be 3 sided and made from aluminum sheet probably. Like so:
