Radical Radiator Relocation?
Old Apr 27, 2009 | 11:22 PM
  #61
JasonWW's Avatar
Next is my kooky little expansion tank. Some may recognize it, most won't. It cost me 6 bucks so it will do for now. I turned this dank little sphere -
Into this!
The cold line is halfway, so it should be easy to check just by taking the cap off and looking inside. It has a built in water lever switch just like our radiators, but I haven't looked into how they work yet. The glossy black should look good in the flat black engine bay. This will mount where the battery used to be.
Old Apr 27, 2009 | 11:34 PM
  #62
JasonWW's Avatar
Here is the factory vacuum reservoir that we all have near the horn. I moved it under the cowl and right above the PCM. It dissappears there. No worries from that any more.
Here is the wiring harness which will disappear soon. You can also see the upper radiator hose.
In this pic you can see the lower hose. Once I take a wider shot you will see that both radiator hoses travel along the frame rails in a symetrical way. I can still stand in front of the engine to easily reach the back spark plugs, etc... BTW, you can tell this is before I filled in the holes on the shock tower.
I also replaced the block to battery ground. Since the battery is being moved, I grounded the block to the K-member. I think it's well connected electrically to the chassis so there should be no worries.
This is the layout I have in my head.
I'll take some more pics soon to get you up to date.
Later.
Old Apr 30, 2009 | 01:49 AM
  #63
JasonWW's Avatar
Originally Posted by JasonWW
Next:
Make lower rad mount - Done
Make bumper cover supports
Hoses - Done
Add expansion tank - Got it, not installed yet
Hood latches (as in 2) - Got it, not installed yet
Hide all underhood wiring - In process
Add beefy lower front bar for lifting and towing
Add more bracing
etc...
Move battery to rear - In process
Hide TCS motor - In process
Filled in holes on shocktowers - Done
Relocated vacuum tank near PCM - Done
Battery is now mounted in rear and can crank on it's own.
Expansion tank is mounted and plumbed into system. Cooling system is done. The vent lines could look better, though.
No wires can be seen from the left shocktower to the right one. Now I need to reroute the ones on the passenger side. I can't go under the shock tower due to tire clearance. I'm going to have to get creative.
Old Apr 30, 2009 | 03:24 AM
  #64
w3s1c0a5t's Avatar
Holy ***** this was cool..
Did it save any weight? Love that you make it happen and dont feel like you need the forums permission.
Very good fab work on those mounts. That definitely took some time and measuring.
Old May 1, 2009 | 12:24 AM
  #65
JasonWW's Avatar
More update pics:
Here's a nice beauty shot. Notice the filled holes in the shocktower and the symetry in the radiator hoses. I also straighted out the ABS unit. The crooked mounting of that always did bother me.
Here is the new battery location. It's not perfect, but will do for now. I welded a bolt to the car for the ground wire to bolt to. I scraped away some of the sound deadner on the floor and welded some threaded rods to the metal. The cables are pretty much out of the way. I'm running a 250 amp fuse for protection.
On the front end I routed the cable to the lug on the fuse box. Pretty straight forward. It's a zero gauge cable and I plan to run some fancy connectors, but these will work for now.
I made a bracket for the expansion tank out of 16 gauge sheet metal.
Here's a shot with the tank mounted and hooked up.
A closer look.
Old May 1, 2009 | 01:07 AM
  #66
JasonWW's Avatar
Here's what I did today.
I cut out a pair of these reinforcements from some heavy plate. About 1/4" thick.
I then welded them to this area which I thought was a little weak. The bottom is designed to fit my small headed jack. A larger jack will also fit it. These are jacking points for when I need to lift only the left or right wheel.
Here's the heavy duty lower bar. It's 1.5" square tube (thicker gauge as well) that serves as the main front jacking point. I can lift the whole car from here. I can also mount rollers on it to keep from damaging the nose on steep driveways.
I don't know if I made the right decision here, but I choose to have the bottom bar hang down below the bumper line. Ah, I guess it's fine.
Old May 1, 2009 | 09:56 AM
  #67
colby72olds's Avatar
Dude, you're the freakin ****! I think it's awesome that you do all those crazy mods.
I want to copy your exhaust tip idea, it gets old polishing them every other week.
Old May 1, 2009 | 02:14 PM
  #68
The Crazy Sweed's Avatar
Freeking awesome! I write more later.. have to go to the sauna! c ya!
Old May 1, 2009 | 08:53 PM
  #69
Devils Mentor's Avatar
Look SICK man; I like your way of thinking!
Question - Why did you just not go with a full tubular front end? I am looking into that right now; I don't like all that sheet metal, lol.
I am looking forward to your other reads! I am hunting down all your threads now
BTW - I just picked up the E-1 bumper; it looks SICK in person!
You may get a kick out of this since your into extreme modding. This is one of my ventures now. I have my buddy designing the hinges right now. The idea is to allow you to open the doors in a normal suicide mod as well as in a vertical suicide position.
Sorry for the Jacking, but it is cool to find a kindred spirit that is into modding something other than Hondas
DM
Old May 1, 2009 | 09:41 PM
  #70
KurtRardin's Avatar
Veteran: Marine Corps
A man who can weld can make anything. Awesome! What type of welder are you using for your fab work? I somehow talk myself out of doing "new" things to my car that havent been done before. You don't seem to have that issue. I'm interested to see the end result.
You know, if you could somehow fab up a remote waterpump... then with a two piece timing cover you could make a cam change as simple as taking the pushrods out... just thought I'd throw that out there...
Old May 2, 2009 | 03:27 AM
  #71
chevroletfreak's Avatar
I am working on exactly the same thing right now. My plan is to run the right side harness through the inside of the driver side framerail. I am planning on drilling a hole in it near the firewall. Then route the wire through to another hole in the front.
Just an idea if you wanna beat me to the punch.
Old May 2, 2009 | 07:21 AM
  #72
JasonWW's Avatar
Thanks for the nice words everyone.
On the exhaust tips, there are 2 things I should have done. Instead of polishing and clearcoating them I should have chromed them. Second, I should have added a rock guard to keep stones from being kicked up and hitting the tips. I'll do that if I put them back on.
Old May 2, 2009 | 07:27 AM
  #73
JasonWW's Avatar
What do you mean "a full tubular front end"? Do you mean from the firewall forward? I'm planning on doing a full tubular frame on my white car Project XTA in my sig. This car doesn't need it. Plus I want to get it back on the road quickly.
I'm familiar with that Supra. I think it was built by JT? Maybe? It used to be silver. Not only is it hinged like that, but it's opened by linear actuator. I was thinking about that for the white car. My biggest concern with flip up hinges is that they open in one motion. I don't like swinging the door out a few inches and then lifting it. That's 2 motions and I won't have it. Right now I'm focused on the black cars front end, then I need to make my HID fixed projector lights, get it inspected and then do up the air suspension. Down the line I want to install an IRS, then I have plenty to do to the white car so I'll be busy for a while. So im not going to consider custom doors for a long time. Keep me informed on your progress, though. I'm very interesting in it.
Old May 2, 2009 | 07:52 AM
  #74
JasonWW's Avatar
I should point out I'm a beginner welder so I went out and bought a small Hobart Handler 125. Its a 110v MIG wire feed welder with 4 power levels and a seperate wire feed speed. Northern Tool has them for $309. It's good quality as well. I'm not using any gas right now, just a flux core wire. It does the job, but splatters some. All I need to go to gas welding is a bottle of gas, a pressure regulator and some solid core wire. This welder is setup for it.
A 2lb spool of wire is about $15.
You can get an auto tinting helmet for about $50. (I highly recommend it for beginners)
A pair of leather welding gloves $10-$15.
MIG pliers come in real handy as well $10.
A wire brush. That's about all you need. That and lots of practice.
I love welding. You can sit there and focus on that puddle making sure you get good penetration without putting a hole in the metal. It's like sharp shooting. You just have to focus and practice, develop techniques alone the way and you'll get better and better at it. It's a personal challenge. I see guys welding with TIGs and it comes out looking amazing. I want one eventually but they are big bucks. MIGs are much more affordable. If you've been thinking about getting one, go out and do it!
Eventually I'll get me a tubing bender and a notcher. Then look out!
Old May 2, 2009 | 08:20 AM
  #75
JasonWW's Avatar
I considered that a long time ago. There's only so many places you can run those wires. The reason I don't want them in the frame rail is because I plan to route cool air for my brakes through the frame. It's very difficult to route a 3" tube from the nose to the rotor and most folks have it hanging under or above the sway bar. It tends to get pinched or scraped up like that. I plan to run air into the frame, the front of which will be welded shut. Then cut a hole to let the air out in the wheel well. You squirt some foam into the rail to force the air out and attach a hose from the rail to the rotor. It's a very clean looking setup and hard to spot unless the wheel is removed.
Hmmm, I might be able to run both the wires and the air through there. Or maybe have the wires exit through the bottom of the frame before it gets to the air duct part. The main thing is to keep the heat away from them. I'm going to have to do some measuring and looking to see what's possible. Thanks for getting my gears turning on this idea.
Did you say your doing this on the drivers side? I'm leaving that side as is becuase they are pretty much already hidden over there. I'm mainly focused on the passenger side. Why are doing the drivers side? Do you have any pics you can post? Go ahead, I want to see.
Ps. Hey, you know SRZ. I remember him, he would tell me about his autobahn runs and such. Small world. Have you ran into Ragtop Rat? He's over there with a killer candy apple maroon TA. His car is amazing as well.
Old May 2, 2009 | 08:54 AM
  #76
Thumbs up
I'm familiar with that Supra. I think it was built by JT? Maybe? It used to be silver. Not only is it hinged like that, but it's opened by linear actuator. I was thinking about that for the white car. My biggest concern with flip up hinges is that they open in one motion. I don't like swinging the door out a few inches and then lifting it. That's 2 motions and I won't have it. Right now I'm focused on the black cars front end, then I need to make my HID fixed projector lights, get it inspected and then do up the air suspension. Down the line I want to install an IRS, then I have plenty to do to the white car so I'll be busy for a while. So im not going to consider custom doors for a long time. Keep me informed on your progress, though. It's very interesting in it.
Yeah I am talking firewall forward and maybe extending it to accept the fiberglass front end that VFN sells as well as making it tilt.
Yep JT in Cal. did the mod. I have a few pics of it, including pics of it when it was silver. What info do you have on it?!? I have been trying to find some video on it as well as pics of the doors and the hinge mechanism. I was told that it is 100% automated. So do you know the owner? This is the only pic I have showing how the part of the hinging works. Please let me know what info you have on it
Fell free to PM me to discuss so we don't derail your thread, unless you want to talk here
DM
Old May 2, 2009 | 08:58 AM
  #77
KurtRardin's Avatar
I'm a manager at harbor freight tools in Knoxville, and I sell the crap out of the 110 mig welders. We also have a book by haynes (the car book people) thats all about welding with all the different types of setups. We sell 220v TIG welders from $199 to $500, and I've never seen someone bring one back or have any trouble with them (im pretty sure all our stuff could interchange with lincoln parts... if you know what I mean
Old May 2, 2009 | 09:03 AM
  #78
I have always wondered about HB welder. I want to learn how to weld, but I don't want to spend an arm and a leg. I might give it a try.
What about their paint gun setups? I want to paint my bird when I am done with all the body issues.
DM
Old May 2, 2009 | 09:21 AM
  #79
KurtRardin's Avatar
Without trying to hijack this thread...
Our paint guns are okay. $15 gets you a $15 paint gun, while $59 gets something decent... something worth cleaning instead of throwing it away and buying a new one because the cleaner costs more than the gun Our 110v flux only wire welders are usually around $99. Guys who just want to try it come in all the time.
As far as other fab work, we've got a tubing notcher for less than $50, hydraulic pipe benders, planishing hammers, english wheels, plasma cutters, etc. If anyone has any questions just PM me... this thread doesnt need my advertisement, lol.
But anyway... I don't know how you feel about the remote waterpump, but the ol' LT1 style electric waterpump can be had for about $100, which all it needs is the stock LT1 housing, minus all the guts. Could be cool...
Old May 2, 2009 | 09:55 AM
  #80
JasonWW's Avatar
I really don't have any issues with the water pump. I may ditch the power steering pump, though. That way you can see more of the engine. I'd convert over to an electro-hydraulic unit which can be remote mounted. Even to the back of the car. You can even ditch the big power brake booster as well. That remote pump can power both.
I'm trying to decide which hood I want to run. I have a Raptor and a steel one. The Raptors pretty nice, but if I fill on the nose area flush with the steel hood you can get a really unique and exotic look. Plus I can do a shaker scoop as well.
Actually, I like the look of the engine bay so much I'm trying to figure out a way to go hoodless. Hotrod style! That would be bitchin. :-)
