View Poll Results: Ground Clearance with TDs
Less then 3 in.
3
13.64%
About 3 in.
4
18.18%
About 4 in.
4
18.18%
About 5 in.
6
27.27%
About 6 in. or more
5
22.73%
Voters: 22. You may not vote on this poll
Ground clearance with TDs
Old Jun 8, 2007 | 09:13 AM
Kavslayer's Avatar
Default Ground clearance with TDs
What do you guys have for ground clearance with your TDs?
Old Jun 8, 2007 | 10:26 AM
jmm98LS1's Avatar
~3" and I'm lowered ~1.75".
Old Jun 8, 2007 | 10:51 AM
tylerdj's Avatar
I had about 4" with TSP duals.
Old Jun 8, 2007 | 05:42 PM
bww3588's Avatar
i got around 5-6 inches....but that took a lot of work to make them fit right.
Old Jun 9, 2007 | 01:28 PM
Jakson's Avatar
~3" with Lanes X on 120k sagged suspension
Old Jun 9, 2007 | 05:45 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I had about 5" on my old Z which was stock ride height
Old Jun 9, 2007 | 05:50 PM
sportsaddict_21's Avatar
2 or 3inches
Old Jun 9, 2007 | 05:52 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Approx 3"
Old Jun 9, 2007 | 08:07 PM
Kavslayer's Avatar
? for you guys with 3 inchs or so do you find your TDs hitting on speed bumps or sharp changes is the roads?
Old Jun 9, 2007 | 08:11 PM
The Professor's Avatar
i never measured it. a better guage would be 1. great 2. tolerable 3. blows
with a lowered car, i'm somewhere between 2 and 3.
Old Jun 9, 2007 | 08:12 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
2.5's give me the clearance I was looking for.
Old Jun 10, 2007 | 12:40 AM
Jakson's Avatar
If I'm by myself, I'm usually fine going down the road. With 2 more people in the car it scrapes every so often. A full car is out of the question, the stock suspension is pretty soft and wore out. If I get new/stiffer springs I would probably be fine. It does scrape on big speed bumps even by myself. Between trying to keep the 315s from rubbing the fenders, and keeping the exhaust from scraping, I really gotta watch where I go!
Old Jun 10, 2007 | 01:12 PM
jimmypop13's Avatar
damn, why are you still on the stock shocks! I couldn't stand mine at 60k so I swapped on new ones and it made a huge difference. I can't even imagine what it would do for you!
Old Jun 10, 2007 | 03:45 PM
Jakson's Avatar
Yeah i def need some new ones, going to try to get some soon.
Old Jun 11, 2007 | 10:14 AM
Silverhawk_02TA's Avatar
Somewhere between 5" and 6" with the TSP duals. Installation is key. Spend the extra time getting everything tucked up nice and tight and your clearance shouldn't be a problem.
Old Jun 12, 2007 | 09:23 AM
lilbuddy1587's Avatar
over 6 inches easily.
Old Jun 12, 2007 | 12:08 PM
m6speed's Avatar
about a soda can on the lowest part on my tsp's
Old Jun 13, 2007 | 12:47 AM
Jakson's Avatar
All you guys with 5"+ suck!
Old Jun 13, 2007 | 02:48 AM
staringback05's Avatar
most guys will tell you about a coke can size...
Old Jun 13, 2007 | 03:11 AM
Nimitz87's Avatar
at first i was scraping everywhere with my TSP true duals and stock ride height...
went to the muffler shop and $30 later had them sitting about another 1-2" higher with the cut hangers and welded them up higher.
I should safely be around 5" at stock ride height and never scrape unless its a huge incline/decline.
thats tsp 3" true duals.
going to lower the car and get 17's so it should stay the same pretty much.
Chad
