TexasSpeed 3'' Y??
Old Jun 10, 2007 | 05:24 PM
1meantransam's Avatar
Default TexasSpeed 3'' Y??
Anyone use the TexasSpeed 3" Y with magnaflow cats? whats the ups and downs and should i spend the 300 on it?
Old Jun 11, 2007 | 09:28 AM
no one in this forum has ever used the TSP y?
Old Jun 11, 2007 | 03:37 PM
HardBlu's Avatar
I just rx'd my y pipe today. If they fit Jet Hot coated LTs to the SLP mid pipe, I should have them installed by next week. Anything is better than the cheap Jet Hot catted Y, poor design - great idea. I could never beat the exhaust leak this Y-pipe inherently has at the cats section. Too bad for me I tried it and wasted the money. I hope these work.
I also noticed there are no bungs for O2 sensors. I have to find someone to delete the rear O2's or have a local muffler shop weld them in. Not sure which is cheaper, 75.00 for a softpatch or the muffler shop. So add the extra cash that is mentioned.
Old Jun 11, 2007 | 09:29 PM
2_wacko's Avatar
I have the TSP catted y pipe great clearance and easy to adjust.
Old Jun 11, 2007 | 10:23 PM
will it fit right up to my Pacesetters??
Old Jun 12, 2007 | 03:54 PM
bump?
Old Jun 12, 2007 | 06:21 PM
2_wacko's Avatar
Slipped right over the pacesetter collectors.
Old Jun 12, 2007 | 07:49 PM
splendid
Old Jun 12, 2007 | 09:00 PM
cals400ex's Avatar
yep i run that same setup with pacesetters LT's. i didn't install it so i can't tell you how the install went. i actually have a little bit of clearance issues with mine. maybe it just needs adjusted.
Old Jun 12, 2007 | 09:16 PM
2000TransAmWS6's Avatar
based on my personal experience TSP's catted y-pipe is "supposed" to fit right up to the Hooker-style headers (i have Jet Hot headers). i do all of my own work to my car, i installed heads and cam in it a couple months ago, and i am GLAD that i took it to an exhaust shop to have them install this y-pipe for me. the exhaust shop welded it up (i don't weld), but they had to cut and flare some of the pipes to get them to fit properly. i say that i am glad that i didn't do it myself, because i watched the guys install it and it would have been a terrible PITA to get those pipes to fit together properly.
after all was said and done i would still buy TSP's catted y-pipe again, from pricing high-flow cats usually a pair of them are $300 from what i found, so it seems like a pretty good deal.
Old Jun 12, 2007 | 11:46 PM
candlelit's Avatar
according to TSP's website, they should bolt right up to Pacesetter & Hooker headers. As for clearance on my 98 Trans Am, the driver side cat sit barely underneath the brake lines & floorboard. The bottom side of that cat is the closest part of my exhaust to the ground. My car sits at stock ride height, and the bottom of the cat sits about 4" or so off the ground (from guess-timation).
I have Hooker long tubes, TSP 3" catted y, and GMMG catback. We had to do a little adjusting, because my headers were only 2.5" pipe. I had a offroad Y pipe on before the catted TSP, and the sound was nice. But after we installed the TSP... it just turned out the best sound. Sounds like a turbo, mean, and tamed v8.
Old Jun 13, 2007 | 09:51 AM
good i just ordered my y pipe and ill be taking it in as soon as i get 300 for the install
Old Jun 13, 2007 | 11:38 AM
$300 for the install, seems pretty steep! i paid $100 to have mine welded up.
Old Jun 13, 2007 | 03:12 PM
candlelit's Avatar
I agree. I paid $60 @ my local muffler shop to install the y pipe & weld on some tips. Installing the catback shouldn't be a problem for them.
Old Jun 13, 2007 | 03:41 PM
gyrene2003's Avatar
u guys paid to have urs put on? Took me and my buddy some time, but thats just because we were on our backs and taking our time. Fit together pretty well for me!!
Old Jun 13, 2007 | 03:48 PM
yeah i know it's stepp but where i live everythings 10 times as much, just like overnight mail is actually 2nd day here. i already have exhaust and all i just need my headers and Y put on. ill look around town see if i can find anything even minorly cheaper
Old Jun 13, 2007 | 03:58 PM
tylerdj's Avatar
Me and my brother installed a TSP ORY on my old car. It was pretty easy...we just had to get a couple pieces expanded a little (such as where it goes over the collector) to make it a little easier. Other than that it all was straight forward and slid right together. Good luck
Old Jun 13, 2007 | 04:01 PM
well hopefully i can find out someone to do it for cheaper (douptful) i lack almost all tools required for the job though so im out of luck on my own
Old Jun 13, 2007 | 04:06 PM
unless someone can tell me exactly ever tool needed and part required to remove to put them in i may be able to do it my self
Old Jun 13, 2007 | 04:37 PM
candlelit's Avatar
I installed the GMMG catback myself, but my y pipe & tips needed to be welded and I don't have a mig to do so
