2.5" duals vs. 3" duals
Old Jun 20, 2007 | 05:26 PM
jlashley2001ss's Avatar
Default 2.5" duals vs. 3" duals
im basing this question on how these two different in sound. Is there much difference in sound with 2.5" true duals from headers all the way over the axle-----compared to 3" duals from headers to 2.5" over axles?
**Both have hi-flow cats
**Both have H-pipe
**Both crush bends
Old Jun 20, 2007 | 06:07 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I would doubt they'd differ much in sound, but that is pure conjecture on my part, as I'm sure most posts will be on this subject due to people not having had both. Not sure you'll get a great answer on this one...
Old Jun 20, 2007 | 09:01 PM
teke184's Avatar
i can't see why they would be significantly different.
if you're just gonna neck it down to 2.5 anyway...why not start with 2.5 and save yourself the ground clearance up front.
Old Jun 21, 2007 | 07:10 AM
Ryanmgaspard's Avatar
I do believe a 2.5" exhaust is good for up to 500hp. I plan to do LT's and 2.5". Low end torque will be better also. I had 2.5" on my T-Bird and talk about no bottom end.
Old Jun 21, 2007 | 08:15 AM
im pretty sure 2.5" from LT's all the way over the axle is what im doing. Stick a couple of medium powerpacks before axle and run pipe over axle.
Old Jun 21, 2007 | 09:51 AM
senicalj4579's Avatar
Yeh man,just go with the 2.5. Youll have better clearance and your power potential will be a few ponies after 500. I wouldnt do 3" unless you really wanna get all you can out of it which would be about 800. Go with the 2.5
Old Jun 21, 2007 | 12:59 PM
TheLS1Kid's Avatar
Is that 500hp to the ground or flywheel?
Old Jun 21, 2007 | 03:28 PM
well thats not totally clear but if I was to make an educated guess it would be at the flywheel
Old Jun 21, 2007 | 03:30 PM
TheLS1Kid's Avatar
Thanks man.
Does anyone else know for sure?
Old Jun 21, 2007 | 05:53 PM
teke184's Avatar
there is no cut and dry answer....no definative hp number.
its not like someone has calculated that at 498.438hp you'll reach the max flow potential of 2.5" pipes.
Old Jun 21, 2007 | 05:57 PM
well yeah there is no cut and dry answer if at the wheels or not but
actually there is a calulation for this. And the max efficiency of 2.5" duels are 513hp
Old Jun 21, 2007 | 10:16 PM
so no real sound difference between the two pipe sizes?
Old Jun 22, 2007 | 12:20 AM
i cant really answer about the sound. but i dont believe there is a big diff if any
Old Jun 22, 2007 | 08:57 AM
slow trap's Avatar
the 3" should be alittle deeper imo.i'd say for a stock cube n/a 346 dual 2.5" and for a stroker motor that moves more air at a lower rpm or a nitrous setup 3" would be better.
Old Jun 22, 2007 | 10:17 AM
jmm98LS1's Avatar
I've had both, the 3" sounds noticeably deeper than the 2.5" but it's not a night & day difference. If I read your post correctly, you're necking back down to 2.5" after the axle anyway, so the sound difference will be negligible.
Old Jun 22, 2007 | 11:05 AM
im going 2.5" all the way...headers back
